------Question for 3-2319933-1 Please Put your question below------
Hello, does the order come with all the connector parts? If so, is it crimped? If not, could you provide the necessary accessories for the connection, including crimping?
Hi @jjordan ,
Welcome to DigiKey TechForum and thanks for your inquiry.
The TE Connectivity part 3-2319933-1 is a 2-position rectangular receptacle housing, designed for female terminals. This part does not include terminals.
- It is a housing only, intended to be used with separately purchased female crimp contacts.
If you want to fully assemble and use this connector, you will need:
- Compatible female crimp contacts (e.g., PCON21 series contacts).
- Cable seals and backshells, if environmental sealing is required.
- Crimping tools suitable for the contact type.
