When automatic mounting MOSFET and PCB relays on a PCB, how much holding force should be applied?
Question:
In the automatic mounting with MOSFET relays and PCB relays on a PC board, how much should the holding force of the tab be applied?
Block
Answer:
Holding-position and holding force for MOSFET relays differ from those of PCB relays. Refer to the holding force described in the explanation.
Block
Explanation:
Pin Strength for Automatic Mounting
In order to maintain the characteristics of the MOSFET relay, the force imposed on any pin of the MOSFET relay for automatic mounting must not exceed the following limits.
For more information, see Common Precautions for All MOSFET Relays: Precautions for Correct Use.
Block
Quick tips
If a relay falls while being picked, make sure that there is not a bent terminal or cracked unit.
Product category Relays MOSFET Relays
Classification Mounting, Storage
Related keywords * MOSFET relay
  • PCB relay
  • Automatic mounting
  • Picking
  • Holding force|
Block
Please visit the link below to see this product line on the Digi-Key website
Relays | Digi-Key Electronics
https://components.omron.com/us-en/faq/relays/FAQE10076
