Question:
If a MOSFET relay and PCB relay will be mounted on a PCB by flow soldering, can the same conditions as PCB relays be applied?
Answer:
The conditions are different from those for relays for PCB. Perform soldering based on the flow soldering in the Explanation.
Explanation:
Flow soldering conditions
The soldering conditions are as follows:
MOS FET relay
- Preheating: 150°C max., 60 to 120 seconds
- Soldering temperature: 260°C, within 10 seconds
- If the recommended conditions are exceeded, the performance of the semiconductor used may deteriorate due to heat.
Perform flow soldering within the recommended conditions.
PCB relay
- Preheating: 110°C max., within 40 seconds
- Soldering temperature: 260°C, within 5 seconds
- Since the temperature and time required for PCB relay soldering are lower than those for MOS FET relay soldering, check the solderability of both relays under PCB relay conditions.
- Flow soldering can be done only once.
For more information, see Common Precautions for All MOS FET Relays: Solder Mounting
For more information, see Safety Precautions for All Relays: 6-10 Automatic Mounting of Relays for PCBs.
Quick tips
Since the flow soldering is guaranteed only once, it is recommended to check the solderability before mass production.
Please visit the link below to see this product line on the Digi-Key website
Relays | Digi-Key Electronics
https://components.omron.com/us-en/faq/relays/FAQE10073
