As an engineer, you often encounter such a problem when facing the selection of fuses, should you choose Fast-Acting or Slow-Blow?
The following are some specific judgment methods and practical examples for this problem:
Basis for judgment:
| Characteristic | Fast acting fuse | Slow acting fuse |
| Fusing speed | Rapid fusing (millisecond level) when overcurrent | Allows short-term inrush currents to pass through (tens of milliseconds to seconds) |
| Applicable scenarios | Surge-free sensitive circuits (e.g. ICs, LEDs) | Circuits with surge or inrush currents (e.g., motors, power supplies) |
| Key parameters | Low I²t value (low fusing energy) | High I²t value (high surge energy tolerance) |
| Typical load characteristics | The steady-state current is stable with no instantaneous spikes | The current rises significantly when starting or switching |
Example of fusing speed comparison: Slow-acting fuses vs. fast-acting fuses
0ABB(slow acting) C2F(Fast acting)
2. Selection steps
Analyze the load characteristics of the circuit, such as whether there is an inrush current?
For example, scenarios such as motor start-up, capacitor charging, and power supply power-on will generate instantaneous currents that are several times the rated current. -
Is the load sensitive?
For example, semiconductor devices (MOSFETs, ICs) need to be quickly cut off from overcurrent to prevent damage. -
Match the fusing characteristics
There is a surge → choose the slow breaking type: avoid the surge causing the fuse to blow by mistake.
No surge → Optional quick break type: Quickly cut off the fault current and protect sensitive components.
- Verify the I²t value
The I²t value (blowing energy) of the fuse needs to be greater than the I²t value of the inrush current (to ensure that the fuse does not blow during the surge).
3. Specific examples
Example 1: LED driver circuit selection
Assumed operating current: 1A (stable, no surge)
Since LEDs are sensitive components, they need to respond quickly to overcurrent or short circuits.
Choose a quick-acting fuse (such as C1F) with a rated current of 1.5A (1.25~1.5 times the working current).
Blows the fuse in milliseconds to protect the LED.
Example 2: Motor control circuit
Assuming operating current: 2A (steady state).
Inrush current: 15A at motor start-up (150ms lasting).
Since the inrush current is much higher than the steady-state current, the fuse needs to withstand short-term overcurrent.
Choose a slow-acting fuse (e.g. C1T) with a rated current of 3A (1.5 times the operating current).
When the motor starts, the 15A current lasts for 150ms, and the fuse does not blow;
If the fault causes the current to continue ≥ 3A, the fuse blows within seconds.
Fourth, summary
Quick-break type: used in scenarios where there is no surge and fast protection is required (such as electronic board and battery protection).
Slow-breaking type: used in scenarios where there is a surge and short-term overcurrent needs to be tolerated (such as motors, power supplies, and inverters).
