When your 5 Band Resistor is not a 5 Band resistor
From time to time I get a question about a 5 band resistor that does not enter into the 5-Band calculator we have on the DigiKey site.
Here we have an example.
No matter if the blue or the black were the first line the bands would not enter correctly into the 5 band calculator. This resistor does work however in the 4-band calculator. Blue, Gray, Silver, Gold.
Now leaves a couple of questions that need to be answered. How do I tell if my resistor is a 4 band or a 5 band? If my 5 band is a 4 band then what is the 5th band?
One key indicator is to look for a gap in the bands. Most resistor companies will put a slightly larger gap between the multiplier and the tolerance gap then between the other bands. Here is an example from Yageo showing a 4 band resistor with a special band.
Here is a similar resistor showing a 5 band from Bourns. Though not as pronounced you can see there is a slightly larger gap between the Multiplier and the Tolerance band.
Now that you have identified that you have a 4 band resistor with a 5th band you want to know what it is calling out. This can also be a bit tricky.
Per IEC 60062:2016 the standard color code would call out Temp Coefficient.
This is not always the case. Yageo for instance uses a Black 5th band in certain series to call out non-inductance.
Trying to identify which you have can range from hard to impossible. If it is a color it is most likely a temp coefficient IEC 60062:2016. If your 5th band is black you are best to try to identify the resistor manufacturer and look at their data sheet.
Do you have a part you are trying to identify? Try thePart Identification category. For other questions feel free to post in the General Category and we will be happy to help.
Here is another example of a 5 band resistor that is Not a Five band resistor.
Let us look at part number 1135-1416-ND from Vishay.
The color bands on it are Brown, Black, Brown, Red and White. As the part number calls out it is a 100 ohm resistor at 2%. This will not include the White band.
The White band is calling out that it is the Military series ML-PRF-22684 with solderable leads
This information can be found on Vishay’s website.
Applicable Vishay Part Numbers
RL20S222GRE6 RL20S222GRE6 RL20S273GB14 RL20S182GRE6 RL20S182GRE6 RL20S223GRE6 RL20S223GRE6 RL20S821GRE6 RL20S821GRE6 RL20S681GB14 RL20S103GB14 RL20S471GB14 RL20S152GB14 RL20S470GB14 RL20S474GB14 RL20S221GB14 RL20S104GB14 RL20S101GB14 RL20S272GRE6 RL20S272GRE6 RL20S333GRE6 RL20S333GRE6 RL20S101GRE6 RL20S101GRE6 RL20S271GRE6 RL20S271GRE6 RL20S152GRE6 RL20S152GRE6 RL20S683GRE6 RL20S683GRE6 RL20S332GB14 RL20S102GB14 RL20S222GB14 RL20S473GB14 RL20S183GB14 RL20S682GB14 RL20S224GB14 RL20S561GB14 RL20S680GB14 RL20S124GB14 RL20S821GB14 RL20S220GB14 RL20S332GR36 RL20S332GR36 RL20S272GB14 RL20S621GB14 RL20S105GRE6 RL20S202GR36 RL20S182GR36 RL20S183GR36 RL20S184GR36 RL20S202JR36 RL20S163GR36 RL20S203GR36 RL20S220GR36 RL20S220JR36 RL20S181GR36 RL20S162GR36 RL20S222GR36 RL20S123GR36 RL20S104GR36 RL20S122GR36 RL20S122JR36 RL20S131GR36 RL20S153GR36 RL20S150JR36 RL20S151GR36 RL20S152JR36 RL20S221GR36 RL20S242GR36 RL20S223GR36 RL20S102JR36 RL20S360GR36 RL20S332JR36 RL20S333GR36 RL20S334GR36 RL20S362JR36 RL20S331GR36 RL20S390GR36 RL20S392GR36 RL20S394GR36 RL20S330JR36 RL20S242JR36 RL20S273GR36 RL20S270GR36 RL20S271GR36 RL20S272JR36 RL20S300GR36 RL20S330GR36 RL20S301GR36 RL20S301JR36 RL20S303GR36 RL20S103GR36 RL20S102GR36 RL20S432GR36 RL20S101GR36 RL20S100GR36 RL20S431GR36 RL20S471GR36 RL20S470GR36 RL20S471JR36 RL20S750GR36 RL20S681GR36 RL20S682GR36 RL20S683GR36 RL20S751GR36 RL20S621GR36 RL20S752GR36 RL20S752JR36 RL20S820GR36 RL20S622GR36 RL20S620GR36 RL20S823GR36 RL20S512GR36 RL20S472GR36 RL20S473GR36 RL20S511GR36 RL20S560GR36 RL20S561GR36 RL20S561JR36 RL20S562GR36 RL20S821GR36 RL20S823JR36 RL20S113GRE6 RL20S114GRE6 RL20S110JRE6 RL20S121GRE6 RL20S111GRE6 RL20S121JRE6 RL20S104GRE6 RL20S103JRE6 RL20S134GRE6 RL20S151JRE6 RL20S151GRE6 RL20S150JRE6 RL20S150GRE6 RL20S134JRE6 RL20S132GRE6 RL20S133GRE6 RL20S122GRE6 RL20S131GRE6 RL20S124GRE6 RL20S123GRE6 RL20S122JRE6 RL20S102JRE6 RL20S103GRE6 RL20S100GRE6 RL20S102GRE6 RL20S182JRE6 RL20S153GRE6 RL20S431GRE6 RL20S393GRE6 RL20S394GRE6 RL20S432JRE6 RL20S432GRE6 RL20S391GRE6 RL20S433GRE6 RL20S470GRE6 RL20S392GRE6 RL20S390GRE6 RL20S390JRE6 RL20S471GRE6 RL20S360GRE6 RL20S332JRE6 RL20S334GRE6 RL20S362GRE6 RL20S361GRE6 RL20S364JRE6 RL20S362JRE6 RL20S363GRE6 RL20S470JRE6 RL20S471JRE6 RL20S331JRE6 RL20S563GRE6 RL20S561JRE6 RL20S562GRE6 RL20S560GRE6 RL20S620GRE6 RL20S621GRE6 RL20S561GRE6 RL20S512JRE6 RL20S513GRE6 RL20S472GRE6 RL20S474GRE6 RL20S472JRE6 RL20S473GRE6 RL20S510JRE6 RL20S510GRE6 RL20S512GRE6 RL20S511GRE6 RL20S511JRE6 RL20S332GRE6 RL20S330JRE6 RL20S331GRE6 RL20S153JRE6 RL20S202JRE6 RL20S201GRE6 RL20S202GRE6 RL20S203JRE6 RL20S203GRE6 RL20S184GRE6 RL20S204GRE6 RL20S220GRE6 RL20S200GRE6 RL20S183GRE6 RL20S221GRE6 RL20S162JRE6 RL20S154GRE6 RL20S162GRE6 RL20S163JRE6 RL20S163GRE6 RL20S181GRE6 RL20S164GRE6 RL20S180GRE6 RL20S220JRE6 RL20S221JRE6 RL20S330GRE6 RL20S300GRE6 RL20S274GRE6 RL20S274JRE6 RL20S301JRE6 RL20S301GRE6 RL20S272JRE6 RL20S302GRE6 RL20S303GRE6 RL20S273GRE6 RL20S270GRE6 RL20S270JRE6 RL20S222JRE6 RL20S240GRE6 RL20S224GRE6 RL20S224JRE6 RL20S242GRE6 RL20S241GRE6 RL20S244GRE6 RL20S242JRE6 RL20S243GRE6 RL20S623GRE6 RL20S622GRE6 RL20S912GRE6 RL20S680GRE6 RL20S681GRE6 RL20S911GRE6 RL20S910GRE6 RL20S910JRE6 RL20S823GRE6 RL20S751GRE6 RL20S682GRE6 RL20S750GRE6 RL20S753GRE6 RL20S752GRE6 RL20S822GRE6 RL20S820GRE6 RL20S821JRE6 RL20S143JB14 RL20S172JB14 RL20S793JB14 RL20S424GB14 RL20S501GB14 RL20S5R1JR36 RL20S8R2JR36 RL20S5R1JRE6 RL20S5R1GRE6 RL20S8R2JRE6 RL20S514JB14 RL20S202GRSL RL20S201GRSL RL20S201JRSL RL20S203GRSL RL20S202JRSL RL20S200GRSL RL20S203JRSL RL20S204GRSL RL20S200JRSL RL20S184GRSL RL20S184JRSL RL20S220JRSL RL20S164GRSL RL20S163GRSL RL20S163JRSL RL20S181GRSL RL20S180GRSL RL20S183GRSL RL20S182GRSL RL20S182JRSL RL20S220GRSL RL20S221GRSL RL20S162GRSL RL20S270GRSL RL20S244GRSL RL20S244JRSL RL20S271GRSL RL20S270JRSL RL20S242JRSL RL20S271JRSL RL20S272GRSL RL20S243GRSL RL20S241GRSL RL20S242GRSL RL20S221JRSL RL20S223GRSL RL20S222GRSL RL20S222JRSL RL20S224GRSL RL20S223JRSL RL20S240JRSL RL20S224JRSL RL20S240GRSL RL20S162JRSL RL20S161GRSL RL20S161JRSL RL20S273GRSL RL20S111JRSL RL20S110JRSL RL20S111GRSL RL20S113GRSL RL20S112GRSL RL20S104GRSL RL20S114GRSL RL20S120GRSL RL20S104JRSL RL20S103GRSL RL20S103JRSL RL20S121JRSL RL20S100GRSL RL20S101GRSL RL20S100JRSL RL20S102JRSL RL20S101JRSL RL20S102GRSL RL20S121GRSL RL20S122GRSL RL20S154GRSL RL20S151JRSL RL20S150JRSL RL20S151GRSL RL20S152JRSL RL20S152GRSL RL20S134JRSL RL20S153GRSL RL20S153JRSL RL20S150GRSL RL20S133JRSL RL20S134GRSL RL20S122JRSL RL20S124GRSL RL20S123GRSL RL20S123JRSL RL20S131GRSL RL20S124JRSL RL20S133GRSL RL20S131JRSL RL20S132GRSL RL20S272JRSL RL20S274GRSL RL20S273JRSL RL20S621GRSL RL20S5R1JRSL RL20S620GRSL RL20S623GRSL RL20S622GRSL RL20S563GRSL RL20S680GRSL RL20S680JRSL RL20S5R1GRSL RL20S561JRSL RL20S562GRSL RL20S681JRSL RL20S511JRSL RL20S510JRSL RL20S511GRSL RL20S512JRSL RL20S512GRSL RL20S561GRSL RL20S513GRSL RL20S560GRSL RL20S681GRSL RL20S682GRSL RL20S474GRSL RL20S910GRSL RL20S823JRSL RL20S8R2JRSL RL20S911GRSL RL20S910JRSL RL20S822GRSL RL20S911JRSL RL20S912GRSL RL20S823GRSL RL20S821GRSL RL20S821JRSL RL20S683GRSL RL20S751GRSL RL20S6R2JRSL RL20S750GRSL RL20S752JRSL RL20S752GRSL RL20S820GRSL RL20S753GRSL RL20S7R5GRSL RL20S510GRSL RL20S472JRSL RL20S473GRSL RL20S274JRSL RL20S332JRSL RL20S331JRSL RL20S332GRSL RL20S334GRSL RL20S333GRSL RL20S330JRSL RL20S360GRSL RL20S361GRSL RL20S331GRSL RL20S304GRSL RL20S330GRSL RL20S362JRSL RL20S301GRSL RL20S300GRSL RL20S300JRSL RL20S302GRSL RL20S301JRSL RL20S303JRSL RL20S302JRSL RL20S303GRSL RL20S362GRSL RL20S363GRSL RL20S472GRSL RL20S434GRSL RL20S432JRSL RL20S433GRSL RL20S470JRSL RL20S470GRSL RL20S431GRSL RL20S471GRSL RL20S471JRSL RL20S432GRSL RL20S394GRSL RL20S430JRSL RL20S364GRSL RL20S390JRSL RL20S364JRSL RL20S390GRSL RL20S392GRSL RL20S391GRSL RL20S393JRSL RL20S392JRSL RL20S393GRSL RL20S9R1GRSL RL20S241GB14 RL20S240GB14 RL20S240JB14 RL20S242JB14 RL20S242GB14 RL20S223JB14 RL20S243GB14 RL20S244GB14 RL20S224JB14 RL20S222JB14 RL20S223GB14 RL20S270GB14 RL20S202JB14 RL20S201JB14 RL20S202GB14 RL20S203JB14 RL20S203GB14 RL20S221JB14 RL20S204GB14 RL20S220JB14 RL20S244JB14 RL20S271GB14 RL20S270JB14 RL20S200JB14 RL20S331JB14 RL20S330JB14 RL20S331GB14 RL20S333GB14 RL20S332JB14 RL20S304GB14 RL20S334GB14 RL20S360GB14 RL20S330GB14 RL20S303GB14 RL20S303JB14 RL20S271JB14 RL20S273JB14 RL20S272JB14 RL20S300JB14 RL20S274GB14 RL20S302JB14 RL20S301GB14 RL20S302GB14 RL20S201GB14 RL20S200GB14 RL20S362GB14 RL20S124JB14 RL20S123GB14 RL20S123JB14 RL20S131JB14 RL20S131GB14 RL20S122GB14 RL20S132GB14 RL20S133GB14 RL20S122JB14 RL20S121GB14 RL20S121JB14 RL20S134GB14 RL20S111GB14 RL20S104JB14 RL20S110JB14 RL20S112GB14 RL20S111JB14 RL20S120GB14 RL20S113GB14 RL20S114GB14 RL20S133JB14 RL20S134JB14 RL20S184JB14 RL20S180GB14 RL20S164GB14 RL20S182GB14 RL20S181GB14 RL20S162JB14 RL20S182JB14 RL20S184GB14 RL20S163JB14 RL20S161JB14 RL20S162GB14 RL20S150GB14 RL20S151JB14 RL20S150JB14 RL20S151GB14 RL20S153GB14 RL20S152JB14 RL20S161GB14 RL20S153JB14 RL20S154GB14 RL20S361GB14 RL20S362JB14 RL20S102JB14 RL20S911GB14 RL20S910GB14 RL20S910JB14 RL20S912GB14 RL20S911JB14 RL20S823GB14 RL20S9R1GB14 RL20S823JB14 RL20S821JB14 RL20S822GB14 RL20S752GB14 RL20S750GB14 RL20S751GB14 RL20S753JB14 RL20S753GB14 RL20S820GB14 RL20S7R5GB14 RL20S683GB14 RL20S6R2JB14 RL20S682JB14 RL20S363GB14 RL20S432JB14 RL20S431GB14 RL20S432GB14 RL20S434GB14 RL20S433GB14 RL20S470JB14 RL20S471JB14 RL20S430JB14 RL20S393JB14 RL20S394GB14 RL20S472JB14 RL20S390GB14 RL20S364GB14 RL20S364JB14 RL20S391GB14 RL20S390JB14 RL20S393GB14 RL20S392GB14 RL20S392JB14 RL20S472GB14 RL20S681JB14 RL20S620GB14 RL20S5R1GB14 RL20S5R1JB14 RL20S622GB14 RL20S562GB14 RL20S623GB14 RL20S680JB14 RL20S563GB14 RL20S560GB14 RL20S561JB14 RL20S510GB14 RL20S511JB14 RL20S510JB14 RL20S511GB14 RL20S512JB14 RL20S512GB14 RL20S513GB14 RL20S513JB14 RL20S103JB14 RL20S101JB14 RL20S100JB14 RL20S100GB14 RL20S330JBSL RL20S304GBSL RL20S330GBSL RL20S331JBSL RL20S331GBSL RL20S303GBSL RL20S332GBSL RL20S332JBSL RL20S303JBSL RL20S302GBSL RL20S302JBSL RL20S334GBSL RL20S274GBSL RL20S273GBSL RL20S273JBSL RL20S300GBSL RL20S274JBSL RL20S301JBSL RL20S300JBSL RL20S301GBSL RL20S333GBSL RL20S361GBSL RL20S360GBSL RL20S272GBSL RL20S432GBSL RL20S430JBSL RL20S431GBSL RL20S433GBSL RL20S432JBSL RL20S393JBSL RL20S434GBSL RL20S470GBSL RL20S394GBSL RL20S392JBSL RL20S393GBSL RL20S362GBSL RL20S364GBSL RL20S362JBSL RL20S363GBSL RL20S390GBSL RL20S364JBSL RL20S392GBSL RL20S390JBSL RL20S391GBSL RL20S272JBSL RL20S271JBSL RL20S471GBSL RL20S200GBSL RL20S184GBSL RL20S184JBSL RL20S201GBSL RL20S200JBSL RL20S182JBSL RL20S201JBSL RL20S202GBSL RL20S183GBSL RL20S181GBSL RL20S182GBSL RL20S203GBSL RL20S162GBSL RL20S161GBSL RL20S161JBSL RL20S163GBSL RL20S162JBSL RL20S180GBSL RL20S163JBSL RL20S164GBSL RL20S202JBSL RL20S204GBSL RL20S203JBSL RL20S271GBSL RL20S243GBSL RL20S242GBSL RL20S242JBSL RL20S244JBSL RL20S244GBSL RL20S240JBSL RL20S270GBSL RL20S270JBSL RL20S241GBSL RL20S224JBSL RL20S240GBSL RL20S220GBSL RL20S221JBSL RL20S220JBSL RL20S221GBSL RL20S222JBSL RL20S222GBSL RL20S224GBSL RL20S223GBSL RL20S223JBSL RL20S470JBSL RL20S471JBSL RL20S153JBSL RL20S9R1GBSL RL20S911JBSL RL20S912GBSL RL20S911GBSL RL20S472GBSL RL20S563GBSL RL20S561JBSL RL20S562GBSL RL20S5R1JBSL RL20S5R1GBSL RL20S560GBSL RL20S620GBSL RL20S621GBSL RL20S561GBSL RL20S512JBSL RL20S513GBSL RL20S623GBSL RL20S474GBSL RL20S472JBSL RL20S473GBSL RL20S510JBSL RL20S510GBSL RL20S512GBSL RL20S511GBSL RL20S511JBSL RL20S622GBSL RL20S680JBSL RL20S680GBSL RL20S910JBSL RL20S822GBSL RL20S821GBSL RL20S821JBSL RL20S823JBSL RL20S823GBSL RL20S7R5GBSL RL20S8R2JBSL RL20S910GBSL RL20S820GBSL RL20S752JBSL RL20S753GBSL RL20S681GBSL RL20S683GBSL RL20S681JBSL RL20S682GBSL RL20S750GBSL RL20S6R2JBSL RL20S752GBSL RL20S750JBSL RL20S751GBSL RL20S154GBSL RL20S153GBSL RL20S152JBSL RL20S104GBSL RL20S103GBSL RL20S103JBSL RL20S110JBSL RL20S104JBSL RL20S102GBSL RL20S111GBSL RL20S111JBSL RL20S102JBSL RL20S101GBSL RL20S101JBSL RL20S113GBSL RL20S100JBSL RL20S100GBSL RL20S112GBSL RL20S120GBSL RL20S114GBSL RL20S150GBSL RL20S134GBSL RL20S134JBSL RL20S151GBSL RL20S150JBSL RL20S133GBSL RL20S151JBSL RL20S152GBSL RL20S133JBSL RL20S131JBSL RL20S132GBSL RL20S121GBSL RL20S122JBSL RL20S121JBSL RL20S122GBSL RL20S123JBSL RL20S123GBSL RL20S131GBSL RL20S124GBSL RL20S124JBSL RL20S4R3GB14
