In the panel-simple.c linux display driver (drivers/gpu/drm/panel/panel-simple.c) there are two structures that can be used to descrive the display features. These structures are:
drm_display_mode
display_timing
Can be used only one of the two, is it right?. My question is: when choose drm_display_mode and when choose display_timing?
struct panel_desc {
* @modes: Pointer to array of fixed modes appropriate for this panel.
* If only one mode then this can just be the address of the mode.
* NOTE: cannot be used with "timings" and also if this is specified
* then you cannot override the mode in the device tree.
const struct drm_display_mode *modes;
/** @num_modes: Number of elements in modes array. */
unsigned int num_modes;
* @timings: Pointer to array of display timings
* NOTE: cannot be used with "modes" and also these will be used to
* validate a device tree override if one is present.
const struct display_timing *timings;
using drm_display_mode is usually a fixed mode, by using display_timing this allows you to force your own special override values in the device-tree… (drm_display_mode = fixed, display_timing = usually defined as a range)…
Hello @RobertCNelson
In the example of the link you indicate me, the maximum, minimum and typical values are defined for some parameters of the timing0 and timing1 structures. I thought that the override values in the devicetree must be a single value for each parameter. By putting more values for a single parameter, what does the system use?
Thanks
