I keep buying pin removal tools that don’t work so thought I should ask before buying the next one. Which pin removal tool works for the 178289-5 connector and A29220-ND pins? Thank you!
Hi @Zstanman, welcome to the DigiKey TechForum!
The extraction tool for 178289-5 is TE part number 234168-1, designed for use with the Dynamic D-3000 Series connectors.
For more detailed information, please refer to the manual of Dynamic Series Connectors from TE.
Hope this helps!
Thank you sir, you’re a life saver!
