I’ve been recently asked if there was a difference between the 3 different color wire seals available for 282080-1
The first color is the Yellow wire seal 281934-2
This wire seal is used for wires with an outside shielding Diameter Range of 1.7mm to 2.4mm
The Red wire seal is 281934-3
This red wire seal is used for wires with an outer diameter range of 2.5-3.3mm
The Green wire seal is 281934-4
This green wire seal is for wires with an outer Diameter of 1.6mm
