When you are looking at a Wurth Film Capacitor part such as 890334026034CS you will not find the CS suffix in the datasheet and it seems to be the same as part 890334026034. The CS however is calling out “Cut Short” and is referencing the lead length.
CS: pins 4±0.5mm, ready to use in manufacturing sites.
For further details click here
without CS: pins 20mm, recommended for prototyping and laboratories.
For further information click here
Applicable Part Numbers
890334023006 890334023017CS 890334023023CS 890334023028 890324024003 890324024002 890334025039CS 890334024005 890324024005 890324025004CS 890324023010CS 890324023008CS 890324023023CS 890334023025 890334023028CS 890334025027CS 890324023025 890324025027 890324024005CS 890334025043 890334025045CS 890334026030CS 890334026034 890324028008 890324028008CS 890493423001CS 890283327008CS 890303427009CS 890303327008CS 890334027021CS 890324027030 890443326007CS 890324027030CS 890273427005CS 890493427007CS 890273327007CS 890283327010CS 890283427007CS 890334027030CS 890443327007CS 890324023028 890324025039 890334025045 890334023015CS 890324023006CS 890324023010 890334025004CS 890334025013CS 890324023015CS 890334023011CS 890324025017CS 890334022007CS 890334023023 890324023025CS 890334025027 890324022017CS 890324023028CS 890334024002 890324025027CS 890334024003 890334025039 890334024005CS 890324026027CS 890334027012CS 890334027012 890334027025CS 890324027025CS 890334023006CS 890324023002 890334023002 890334023008CS 890334023002CS 890334025009 890324023017 890334023021 890324023019CS 890334025009CS 890324025006CS 890324025009CS 890334023019CS 890324023015 890334025006CS 890334023011 890334025015CS 890324025013CS 890324025011 890334022007 890324022007 890334025017CS 890324025017 890334025017 890334025020CS 890334025022CS 890334022017CS 890334024001 890324025022CS 890324022017 890324025022 890334024002CS 890324024003CS 890334024003CS 890324026003CS 890324025034CS 890324025034 890334025043CS 890334026018 890334026020CS 890334026020 890324026020 890334026024CS 890324026024 890334026027CS 890334026027 890324026027 890334026030 890324026030CS 890324026030 890334026034CS 890324026034CS 890334027025 890324027025 890334028008 890283322006CS 890283422001CS 890273422002CS 890283422005CS 890303322005CS 890493422002CS 890273322005CS 890303422005CS 890443322001CS 890273423002CS 890303423005CS 890283323001CS 890303323004CS 890283323005CS 890283423001CS 890273323004CS 890443323004CS 890324026007CS 890334026007 890334026007CS 890334026014 890334026014CS 890324026014CS 890283325002CS 890303325004CS 890303425004CS 890283425002CS 890273425001CS 890493425001CS 890273325005CS 890283325008CS 890283425008CS 890273425007CS 890493425009CS 890303325010CS 890303325008CS 890273325009CS 890283326003CS 890303326003CS 890283426004CS 890273326003CS 890263425004CS 890443325010CS 890283326009CS 890303326009CS 890263426001CS 890283426008CS 890303426008CS 890493426011CS 890263426003CS 890273326007CS 890283327004CS 890303428008CS 890283428007CS 890493428013CS 890324023023 890324025039CS 890334023017 890324023011CS 890334023025CS 890324026034 890334023015 890324023006 890324023011 890334022017 890334026003CS 890334026018CS 890324026018 890324026018CS 890324025045 890324025045CS 890324026020CS 890334027006 890334027006CS 890324027006 890324026024CS 890324027012CS 890334023003CS 890334023004CS 890334023007CS 890334023010CS 890324023002CS 890324023003CS 890324023004CS 890334023003 890334023004 890334023007 890334023008 890334023010 890324023003 890324023004 890334023021CS 890334025007CS 890334025011CS 890324023007CS 890324023017CS 890324025007CS 890334023019 890334025004 890334025006 890334025007 890334025011 890334025013 890324023007 890324023008 890324023019 890324025004 890324025006 890324025007 890324025009 890324025015CS 890334023024CS 890324022007CS 890324023021CS 890324025011CS 890334023024 890334025015 890324023021 890324025013 890324025015 890324023024CS 890324025020CS 890334025020 890334025022 890324023024 890324025020 890334025025CS 890334024001CS 890334025031CS 890334025025 890324024001CS 890324025025CS 890334025031 890324024001 890324025025 890334025034CS 890324024002CS 890324025031CS 890334025034 890324025031 890334026003 890324026003 890324025043CS 890324025043 890324027006CS 890334026024 890324027012 890334028008CS
732-5824-ND 732-5730-ND 732-5733-ND 732-5836-ND 732-5889-ND 732-5888-ND 732-5755-ND 732-5840-ND 732-5890-ND 732-5791-ND 732-5777-ND 732-5776-ND 732-5783-ND 732-5835-ND 732-5736-ND 732-5752-ND 732-5885-ND 732-5902-ND 732-5790-ND 732-5856-ND 732-5757-ND 732-5763-ND 732-5864-ND 732-5918-ND 732-5818-ND 732-11818-ND 732-11857-ND 732-11863-ND 732-11858-ND 732-11875-ND 732-11876-ND 732-11847-ND 732-11877-ND 732-11860-ND 732-11861-ND 732-11856-ND 732-11859-ND 732-11862-ND 732-11878-ND 732-11855-ND 732-5886-ND 732-5905-ND 732-5857-ND 732-5729-ND 732-5774-ND 732-5877-ND 732-5741-ND 732-5746-ND 732-5779-ND 732-5728-ND 732-5798-ND 732-5719-ND 732-5833-ND 732-5785-ND 732-5852-ND 732-5770-ND 732-5786-ND 732-5838-ND 732-5802-ND 732-5839-ND 732-5855-ND 732-5740-ND 732-5812-ND 732-5766-ND 732-5866-ND 732-5767-ND 732-5817-ND 732-5724-ND 732-5871-ND 732-5821-ND 732-5726-ND 732-5721-ND 732-5844-ND 732-5880-ND 732-5832-ND 732-5781-ND 732-5744-ND 732-5792-ND 732-5794-ND 732-5731-ND 732-5879-ND 732-5742-ND 732-5828-ND 732-5747-ND 732-5796-ND 732-5895-ND 732-5819-ND 732-5869-ND 732-5748-ND 732-5898-ND 732-5848-ND 732-5749-ND 732-5750-ND 732-5720-ND 732-5837-ND 732-5800-ND 732-5870-ND 732-5900-ND 732-5738-ND 732-5789-ND 732-5739-ND 732-5808-ND 732-5804-ND 732-5904-ND 732-5756-ND 732-5859-ND 732-5760-ND 732-5860-ND 732-5910-ND 732-5761-ND 732-5911-ND 732-5762-ND 732-5862-ND 732-5912-ND 732-5863-ND 732-5813-ND 732-5913-ND 732-5764-ND 732-5814-ND 732-5867-ND 732-5917-ND 732-5868-ND 732-11810-ND 732-11811-ND 732-11812-ND 732-11813-ND 732-11808-ND 732-11815-ND 732-11807-ND 732-11814-ND 732-11809-ND 732-11816-ND 732-11822-ND 732-11819-ND 732-11821-ND 732-11820-ND 732-11817-ND 732-11823-ND 732-11824-ND 732-11869-ND 732-11870-ND 732-11871-ND 732-11873-ND 732-11874-ND 732-11872-ND 732-11827-ND 732-11830-ND 732-11831-ND 732-11828-ND 732-11826-ND 732-11829-ND 732-11825-ND 732-11834-ND 732-11838-ND 732-11833-ND 732-11839-ND 732-11836-ND 732-11835-ND 732-11832-ND 732-11842-ND 732-11843-ND 732-11849-ND 732-11841-ND 732-11837-ND 732-11840-ND 732-11845-ND 732-11846-ND 732-11848-ND 732-11851-ND 732-11852-ND 732-11853-ND 732-11850-ND 732-11844-ND 732-11854-ND 732-11864-ND 732-11865-ND 732-11866-ND 732-5883-ND 732-5805-ND 732-5830-ND 732-5778-ND 732-5735-ND 732-5914-ND 732-5829-ND 732-5874-ND 732-5878-ND 732-5820-ND 732-5758-ND 732-5759-ND 732-5909-ND 732-5809-ND 732-5907-ND 732-5807-ND 732-5810-ND 732-5865-ND 732-5765-ND 732-5915-ND 732-5811-ND 732-5816-ND 732-5722-ND 732-5723-ND 732-5725-ND 732-5727-ND 732-5771-ND 732-5772-ND 732-5773-ND 732-5822-ND 732-5823-ND 732-5825-ND 732-5826-ND 732-5827-ND 732-5872-ND 732-5873-ND 732-5732-ND 732-5743-ND 732-5745-ND 732-5775-ND 732-5780-ND 732-5793-ND 732-5831-ND 732-5841-ND 732-5842-ND 732-5843-ND 732-5845-ND 732-5846-ND 732-5875-ND 732-5876-ND 732-5881-ND 732-5891-ND 732-5892-ND 732-5893-ND 732-5894-ND 732-5797-ND 732-5734-ND 732-5769-ND 732-5782-ND 732-5795-ND 732-5834-ND 732-5847-ND 732-5882-ND 732-5896-ND 732-5897-ND 732-5784-ND 732-5799-ND 732-5849-ND 732-5850-ND 732-5884-ND 732-5899-ND 732-5751-ND 732-5737-ND 732-5753-ND 732-5851-ND 732-5787-ND 732-5801-ND 732-5853-ND 732-5887-ND 732-5901-ND 732-5754-ND 732-5788-ND 732-5803-ND 732-5854-ND 732-5903-ND 732-5858-ND 732-5908-ND 732-5806-ND 732-5906-ND 732-5815-ND 732-5861-ND 732-5916-ND 732-5768-ND
