Introduction
Documentation
- Digi Documentation: Digi Embedded Yocto | ConnectCore 8M Nano
Required packages (Debian 10)
sudo apt update
sudo apt install build-essential chrpath curl diffstat g++-multilib gawk \
gcc-multilib git libsdl1.2-dev minicom socat texinfo unzip wget xterm
Install Repo:
sudo curl -o /usr/local/bin/repo http://commondatastorage.googleapis.com/git-repo-downloads/repo
sudo chmod a+x /usr/local/bin/repo
Install Digi’s dey manifest:
repo init -u https://github.com/digi-embedded/dey-manifest.git -b gatesgarth
repo sync -j8 --no-repo-verify
mkdir -p workspace/ccimx8mn-dvk
cd workspace/ccimx8mn-dvk/
source ../../mkproject.sh -p ccimx8mn-dvk
Example: adding additional packages to default project:
For example, if you needed python3-pip, python3-supervisor, you can add them to the recipe by adding:
echo 'IMAGE_INSTALL_append = " git nano python3 python3-pip python3-supervisor"' >> conf/local.conf
Build base project
bitbake dey-image-qt
Setup microSD to flash files to eMMC:
Format as fat32:
Copy dey-image-qt output files to microSD
cd ./tmp/deploy/images/ccimx8mn-dvk/ ;\
sudo cp -vL ./dey-image-qt-xwayland-ccimx8mn-dvk.boot.vfat /media/voodoo/MICROSD/ ;\
sudo cp -vL ./dey-image-qt-xwayland-ccimx8mn-dvk.ext4.gz /media/voodoo/MICROSD/ ;\
sudo cp -vL ./dey-image-qt-xwayland-ccimx8mn-dvk.recovery.vfat /media/voodoo/MICROSD/ ;\
sudo cp -vL ./imx-boot-ccimx8mn-dvk.bin /media/voodoo/MICROSD/ ;\
sudo cp -vL ./install_linux_fw_sd.scr /media/voodoo/MICROSD/ ;\
sudo cp -vL ./install_linux_fw_usb.scr /media/voodoo/MICROSD/ ;\
sudo cp -vL ./install_linux_fw_uuu.sh /media/voodoo/MICROSD/ ;\
gunzip /media/voodoo/MICROSD/dey-image-qt-xwayland-ccimx8mn-dvk.ext4.gz
Board, update eMMC thru u-boot from files on microSD:
U-Boot console over J16 - Console:
flash target is MMC:0
Net: eth0: ethernet@30be0000
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
Run install_linux_fw_sd to copy files from microSD to eMMC:
=> run install_linux_fw_sd
Custom Kernel:
diff --git a/meta-digi-arm/conf/layer.conf b/meta-digi-arm/conf/layer.conf
index ce7a33cd..61b8fb94 100644
--- a/meta-digi-arm/conf/layer.conf
+++ b/meta-digi-arm/conf/layer.conf
@@ -35,3 +35,4 @@ DIGI_GIT ?= "${DIGI_LOG_GIT}"
DIGI_PKG_SRC ?= "https://ftp1.digi.com/support/digiembeddedyocto/source"
DIGI_GITHUB_GIT ?= "git://github.com/digi-embedded"
+RCN_GITHUB_GIT ?= "git://github.com/rcn-ee"
diff --git a/meta-digi-arm/recipes-kernel/linux/linux-dey-src.inc b/meta-digi-arm/recipes-kernel/linux/linux-dey-src.inc
index 407f673c..a6b228d9 100644
--- a/meta-digi-arm/recipes-kernel/linux/linux-dey-src.inc
+++ b/meta-digi-arm/recipes-kernel/linux/linux-dey-src.inc
@@ -4,11 +4,11 @@ LICENSE = "GPLv2"
LIC_FILES_CHKSUM = "file://COPYING;md5=bbea815ee2795b2f4230826c0c6b8814"
LOCALVERSION = "-dey"
-SRCBRANCH = "v5.4/dey-3.2/maint"
+SRCBRANCH = "v5.4/dey-3.2/maint-sdc30"
SRCREV = "${AUTOREV}"
# Select internal or Github Linux repo
-LINUX_GIT_URI ?= "${@oe.utils.conditional('DIGI_INTERNAL_GIT', '1' , '${DIGI_GIT}linux-2.6.git', '${DIGI_GITHUB_GIT}/linux.git;protocol=https', d)}"
+LINUX_GIT_URI ?= "${@oe.utils.conditional('DIGI_INTERNAL_GIT', '1' , '${DIGI_GIT}linux-2.6.git', '${RCN_GITHUB_GIT}/digi-embedded-linux.git;protocol=https', d)}"
SRC_URI = "${LINUX_GIT_URI};branch=${SRCBRANCH}"
S = "${WORKDIR}/git"
