119-525-99-011-ND
------Question for 525-99-011 Please Put your question below------
What type of connector should be used? Is the pivot available, or does it need to be custom-made?
The datasheet calls out the connector part number on page 3 of the datasheet.
The connector is 12065287 which is an Aptiv part number.
DigiKey sells pre-assembled harnesses for this connector in cable lengths of 1m and 3m. 3685301 1m and 3685302 3m.
Hi @mgauthier911
Connector: The 525-99-011 (119-525-99-011-ND) mates with an Aptiv Metri-Pack 150 Series connector. Housing/seal 12065287, terminal 12047680 (p.3 of the CTS datasheet). DigiKey doesn’t stock these.
Pivot/drive: It uses a spring-loaded “Tang Drive” (p.1). For shaft/mounting recommendations, it is best to contact CTS directly.
