1649-SEN50-SDN-T-ND
I bought some 1649-SEN50-SDN-T-ND sensors, and need connectors or flying lead cable assembly.
The sensor sensor is equipped with a ACES 51451-0060N-001 connector socket.
Sensirion recommends two compatible plugs.
JST GHR-06V-S (DK number 455-1596-ND) (available but pins are 0 stock.)
  • Is there an equivalent plug assembly with flying leads that I can use?
  • If not, can you recommend another compatible plug with pins the you carry stock?
Thanks
Greetings,
1568-CAB-18079-ND may be an item of interest.
