BLDC BrushLess Direct Current Motors
2-wire brushless motors offer simplicity and ease of use. These are powered by simply applying voltage. The speed can be controlled by varying the voltage or through the use of PWM (pulse width modulation). These are commonly used in lower grade applications being they are less efficient and do not offer precise control. Depending on the exact motor, motor direction can sometimes be changed by reversing the polarity.
3-wire brushless motors offer higher efficiency and smoother, more precise control. Each wire typically represents one phase of the motor, otherwise known as windings or coils. These typically require a compatible ESC (electronic speed controller), to manage the timing sequence of power applied to each of the (3) coils. The ESC is sometimes built inside the motor assembly such as part 4686-PN00220-ND, included externally such as 1738-FIT0633-ND | 1738-FIT0632-ND, or purchased separately. Along with controlling the timing, the ESC is also responsible for varying the speed and rotational direction of the motor.
Tech Tip: “Sensored” BLDC motors and compatible ESC offer even further efficiency and control, while also reducing or eliminating startup hesitation (cogging) since the controller knows the precise position of the armature.
Tech Tip: The 3 wires can be connected in any order on the speed controller output, if the motor spins in the wrong direction, simply swap any 2 of the 3 wires to reverse the rotation.
Click Here for DigiKey BLDC Motors
Click Here for all DigiKey Motors - AC, DC
Related Topics
How can I run two brushless DC motors at simultaneous RPM?
Applicable Part Numbers
| DK Part # | Mfr Part # |
| 1670-VW0625AB001G-ND | VW0625AB001G |
| 1568-ROB-20441-ND | ROB-20441 |
| 505-QBL4208-41-04-006-ND | QBL4208-41-04-006 |
| 505-QBL4208-61-04-013-ND | QBL4208-61-04-013 |
| 668-HD-EM0802-LW30-R-ND | HD-EM0802-LW30-R |
| 1670-VW0525AB001D-ND | VW0525AB001D |
| 1670-VW0825AB001G-ND | VW0825AB001G |
| 668-HD-EM0602-LW15-R-ND | HD-EM0602-LW15-R |
| 942-BML5C01CH3-ND | BML5C01CH3 |
| 942-DIA42B10W-ND | DIA42B 10W |
| 1670-VZ7AL2B1692082-L15-ND | VZ7AL2B1692082-L15 |
| 1670-VG1030001XH-ND | VG1030001XH |
| 1670-VW1234AB001U-ND | VW1234AB001U |
| 1670-VZ3TH5B3120076P-ND | VZ3TH5B3120076P |
| 1670-VZ3TL2B3120034P-ND | VZ3TL2B3120034P |
| 1670-VG2080001-175H-ND | VG2080001-175H |
| 4052-C0625BLDCL12-ND | C0625BLDCL12 |
| 4052-C1234BLDCL45-ND | C1234BLDCL45 |
| 4052-C1234BLDCL45F-ND | C1234BLDCL45F |
| 4052-C0825BLDCL12-ND | C0825BLDCL12 |
| 3982-DCM-1035-ND | DCM-1035 |
| 4677-SE020A-ND | SE020A |
| 4677-SM100B-ND | SM100B |
| 4686-PN00220-ND | PN00220 |
| 4677-SCM010-ND | SCM010 |
| 4677-SE010A-ND | SE010A |
| 4677-SCM020-ND | SCM020 |
| 4677-SCM040-ND | SCM040 |
| 4677-SE040A-ND | SE040A |
| 4677-SH100C-ND | SH100C |
| 4677-SCM200-ND | SCM200 |
| 4677-SH200B-ND | SH200B |
| 2090-BL23E22-01D-06RO-ND | BL23E22-01D-06RO |
| 2090-BL34E34-01D-05RO-ND | BL34E34-01D-05RO |
| 1738-1157-ND | FIT0441 |
| 2090-BL17E19-01-RO-ND | BL17E19-01-RO |
| 505-QBL5704-116-04-042-ND | QBL5704-116-04-042 |
| 403-3011162008-ND | 3011162008 |
| 2090-BL17E19-01D-03RO-ND | BL17E19-01D-03RO |
| 2090-BL17E19-02D-03RO-ND | BL17E19-02D-03RO |
| 505-QBL4208-61-04-013-1K-ND | QBL4208-61-04-013-1K |
| 2090-BL17E40-01D-05RO-ND | BL17E40-01D-05RO |
| 2090-BL23E33-01D-04RO-ND | BL23E33-01D-04RO |
| 381-3629-ND | VM.VD4915BK1 |
| 403-3011223006-ND | 3011223006 |
| 403-3011223003-ND | 3011223003 |
| 403-3011222008-ND | 3011222008 |
| 2090-SBL60D2-03-ND | SBL60D2-03 |
| 381-3632-ND | VG.ECI4240BK1.PP42.2.30 |
| 403-3011224007-ND | 3011224007 |
| 2090-SBL80D3-03-ND | SBL80D3-03 |
| 381-3649-ND | VM.VDC4915BK4 |
| 403-7011905341-ND | 7011905341 |
| 505-QBL4208-81-04-019-ND | QBL4208-81-04-019 |
| 505-QBL5704-94-04-032-ND | QBL5704-94-04-032 |
| 505-QBL4208-100-04-025-ND | QBL4208-100-04-025 |
| 505-QBL4208-100-04-025-1K-ND | QBL4208-100-04-025-1K |
| 381-3627-ND | VM.ECI4240BK1 |
| 381-3631-ND | VG.ECI4240BK1.PP42.1.5 |
| 381-3628-ND | VM.ECI6340BK1 |
| 505-PD42-2-1670-TMCL-ND | PD42-2-1670-TMCL |
| 381-3643-ND | VG.VD4915BK1.EC75.1.4 |
| 505-PD42-3-1670-CANOPEN-ND | PD42-3-1670-CANOPEN |
| 505-PD42-3-1670-TMCL-ND | PD42-3-1670-TMCL |
| 381-3633-ND | VG.ECI4240BK1.EC52.1.4 |
| 381-3641-ND | VG.VD4915BK1.P63.1.5 |
| 403-3011222007-ND | 3011222007 |
| 381-3642-ND | VG.VD4915BK1.P63.2.30 |
| 381-3634-ND | VG.ECI4240BK1.EC52.2.33 |
| 381-3640-ND | VG.ECI6360DK1.PP63.2.30 |
| 381-3637-ND | VG.ECI6340BK1.EC75.1.4 |
| 381-3644-ND | VG.VD4915BK1.EC75.2.33 |
| 381-3638-ND | VG.ECI6340BK1.EC75.2.33 |
| 403-7011906118-ND | 7011906118 |
| 381-3648-ND | VM.ECI6340BK4 |
| 403-3011162006-ND | 3011162006 |
| 403-3011223002-ND | 3011223002 |
| 2090-BL17E28-01D-03RO-ND | BL17E28-01D-03RO |
| 403-3011223001-ND | 3011223001 |
| 403-3013162002-ND | 3013162002 |
| 403-3013162001-ND | 3013162001 |
| 403-3013162005-ND | 3013162005 |
| 403-3011222005-ND | 3011222005 |
| 381-3630-ND | VM.ECI6360DK1 |
| 381-3635-ND | VG.ECI6340BK1.P63.1.5 |
| 403-3011224008-ND | 3011224008 |
| 403-3011224000-ND | 3011224000 |
| 403-7011906117-ND | 7011906117 |
| 381-3639-ND | VG.ECI6360DK1.PP63.1.5 |
| 381-3636-ND | VG.ECI6340BK1.P63.2.30 |
| 403-3011224004-ND | 3011224004 |
| 403-7011905340-ND | 7011905340 |
| 403-7011906002-ND | 7011906002 |
| 403-3011352007-ND | 3011352007 |
| 966-1924-ND | 80149509 |
| 966-1644-ND | 80141013 |
| 966-1645-ND | 80141015 |
| 966-1669-ND | 80281019 |
| 2090-BL17E28-01-RO-ND | BL17E28-01-RO |
| 1589-MMS742038-24-S1-1-ND | MMS742038-24-S1-1 |
| 1589-MMS742038-24-R1-1-ND | MMS742038-24-R1-1 |
| 1589-MMS742052-24-S1-1-ND | MMS742052-24-S1-1 |
| 1589-MMS742052-24-R1-1-ND | MMS742052-24-R1-1 |
| 1589-MMS742077-24-S1-1-ND | MMS742077-24-S1-1 |
| 1589-MMS742077-24-R1-1-ND | MMS742077-24-R1-1 |
| 1589-MMS742105-24-S1-1-ND | MMS742105-24-S1-1 |
| 1589-MMS757094-36-S1-1-ND | MMS757094-36-S1-1 |
| 1589-MMS757094-36-R1-1-ND | MMS757094-36-R1-1 |
| 1589-MMS742105-24-R1-1-ND | MMS742105-24-R1-1 |
| 1589-MMS757141-36-S1-1-ND | MMS757141-36-S1-1 |
| 1589-MMS757141-36-R1-1-ND | MMS757141-36-R1-1 |
| 1589-MMS757188-36-S1-1-ND | MMS757188-36-S1-1 |
| 1589-MMS757188-36-R1-1-ND | MMS757188-36-R1-1 |
| 2090-SLU22CH048-24-M16-1024-ND | SLU22CH048-24-M16-1024 |
| 2090-SBL40D1-04-ND | SBL40D1-04 |
| 2090-SLU16CH036-24-G103-M16-1024-ND | SLU16CH036-24-G103-M16-1024 |
| 2090-SLU16CH036-24-G172-M16-1024-ND | SLU16CH036-24-G172-M16-1024 |
| 2090-SBL40D2-02-ND | SBL40D2-02 |
| 2090-SLU16CH052-24-G172-M16-1024-ND | SLU16CH052-24-G172-M16-1024 |
| 2090-SLU16CH052-24-G406-M16-1024-ND | SLU16CH052-24-G406-M16-1024 |
| 2090-SLU16CH036-24-G21-M16-1024-ND | SLU16CH036-24-G21-M16-1024 |
| 2090-SLU16CH036-24-G83-M16-1024-ND | SLU16CH036-24-G83-M16-1024 |
| 2090-SBL60D1-03-ND | SBL60D1-03 |
| 2090-SLU30CH064-24-M24-1024-ND | SLU30CH064-24-M24-1024 |
| 2090-SLU16CH036-24-G406-M16-1024-ND | SLU16CH036-24-G406-M16-1024 |
| 2090-SBL60D2-02-ND | SBL60D2-02 |
| 2090-SLU22CH048-24-G111-M16-1024-ND | SLU22CH048-24-G111-M16-1024 |
| 2090-SLU16CH052-24-G21-M16-1024-ND | SLU16CH052-24-G21-M16-1024 |
| 2090-SLU16CH052-24-G83-M16-1024-ND | SLU16CH052-24-G83-M16-1024 |
| 2090-SLU22CH048-24-G16-M16-1024-ND | SLU22CH048-24-G16-M16-1024 |
| 2090-SLU30CH064-24-G35-M24-1024-ND | SLU30CH064-24-G35-M24-1024 |
| 2090-SLU30CH064-24-G100-M24-1024-ND | SLU30CH064-24-G100-M24-1024 |
| 2090-SBL80D2-01-ND | SBL80D2-01 |
| 2090-SLU22CH048-24-G546-M16-1024-ND | SLU22CH048-24-G546-M16-1024 |
| 2090-SLU30CH064-24-G253-M24-1024-ND | SLU30CH064-24-G253-M24-1024 |
| 1670-VW0934AB001G-ND | VW0934AB001G |
| 1670-VW0934AB007G-ND | VW0934AB007G |
| 2685-MOT-BL-42S1-24V-ND | MOT-BL-42S1-24V |
| 2685-MOT-BL-57S6R-24V-ND | MOT-BL-57S6R-24V |
| 2685-MOT-I-81576-CS-ND | MOT-I-81576-CS |
| 2685-MOT-BL-42S4-24V-ND | MOT-BL-42S4-24V |
| 5293-3000003959-ND | 3000003959 |
| 942-121388800010A-ND | 121388800010A |
| 3026-OVU00212-004-ND | OVU00212-004 |
| 3026-OVU00213-004-ND | OVU00213-004 |
| 3026-OVU00243-004-ND | OVU00243-004 |
| 2685-MOT-I-81535-ND | MOT-I-81535 |
| 2685-MOT-I-81465-ND | MOT-I-81465 |
| 966-1909-ND | 80280501 |
| 2090-BL17E28-02D-03RO-ND | BL17E28-02D-03RO |
| 3026-OVU00244-004-ND | OVU00244-004 |
| 2090-BL23E22-02D-05RO-ND | BL23E22-02D-05RO |
| 2685-MOT-I-81614-ND | MOT-I-81614 |
| 2090-BL34E21-02D-03RO-ND | BL34E21-02D-03RO |
| 2090-BL17E40-02D-03RO-ND | BL17E40-02D-03RO |
| 2685-MOT-I-81670-BL42H-ND | MOT-I-81670-BL42H |
| 2090-BL34E21-01D-07RO-ND | BL34E21-01D-07RO |
| 2685-MOT-I-81522-ND | MOT-I-81522 |
| 2685-MOT-I-81491-L-ND | MOT-I-81491-L |
| 3026-OVU20012-ND | OVU20012 |
| 2090-SBL80D1-03-ND | SBL80D1-03 |
| 4170-BL23E33-02-HP05-ND | BL23E33-02-HP05 |
| 4677-SCM100-ND | SCM100 |
| 4677-SCM100-E-ND | SCM100-E |
| 4677-SH100B-ND | SH100B |
| 4170-BL23E48-02-HP20-ND | BL23E48-02-HP20 |
| 966-1646-ND,2266-80141017-ND | 80141017 |
| 966-1647-ND,2266-80141019-ND | 80141019 |
| 966-1648-ND,2266-80141022-ND | 80141022 |
| 966-1650-ND | 80149518 |
| 3026-OVU00247-ND | OVU00247 |
| 966-1655-ND,2266-80149528-ND | 80149528 |
| 966-1643-ND,2266-80141005-ND | 80141005 |
| 966-1663-ND,2266-80281006-ND | 80281006 |
| 966-1664-ND,2266-80281008-ND | 80281008 |
| 966-1665-ND,2266-80281010-ND | 80281010 |
| 966-1667-ND,2266-80281014-ND | 80281014 |
| 966-1662-ND | 80280302 |
| 2685-MOT-BL-42S3-24V-ND | MOT-BL-42S3-24V |
| 2685-MOT-BL-57S2R-36V-ND | MOT-BL-57S2R-36V |
| 5293-3000001370-ND | 3000001370 |
| 5293-3000003967-ND | 3000003967 |
| 2685-MOT-BL-57S3R-36V-ND | MOT-BL-57S3R-36V |
| 2685-MOT-BL-57S4R-36V-ND | MOT-BL-57S4R-36V |
| 2685-MOT-BL-4266A-24V-ND | MOT-BL-4266A-24V |
| 2685-MOT-I-81685-ND | MOT-I-81685 |
| 4170-BL23E33-02-HP10-ND | BL23E33-02-HP10 |
| 4170-BL23E22-02-HP05-ND | BL23E22-02-HP05 |
| 4170-BL23E22-02-HP10-ND | BL23E22-02-HP10 |
| 2685-MOT-I-81542-A-ND | MOT-I-81542-A |
| 4170-BL23E48-02-HP10-ND | BL23E48-02-HP10 |
| 4170-BL23E48-02-HP05-ND | BL23E48-02-HP05 |
| 4170-BL23E22-02-HP20-ND | BL23E22-02-HP20 |
| 4170-BL23E22-02-HP50-ND | BL23E22-02-HP50 |
| 4170-BL23E33-02-HP50-ND | BL23E33-02-HP50 |
| 4170-BL23E33-02-HP20-ND | BL23E33-02-HP20 |
| 4170-BL23E48-02-HP50-ND | BL23E48-02-HP50 |
| 403-3011162009-ND | 3011162009 |
| 2090-BL34E27-02D-03RO-ND | BL34E27-02D-03RO |
| 2090-BL23E48-02D-03RO-ND | BL23E48-02D-03RO |
| 505-PD42-1-1670-TMCL-ND | PD42-1-1670-TMCL |
| 505-PD42-1-1670-CANOPEN-ND | PD42-1-1670-CANOPEN |
| 966-1660-ND | 80280007 |
| 942-DIX36B-ND | DIX36B |
| 1738-FIT0633-ND | FIT0633 |
| 1738-FIT0632-ND | FIT0632 |
| 942-DIA42B20W-ND | DIA42B 20W |
| 403-3011162004-ND | 3011162004 |
| 505-PD42-2-1670-CANOPEN-ND | PD42-2-1670-CANOPEN |
| 966-1641-ND | 80140059 |
| 403-3011352005-ND | 3011352005 |
| 966-1908-ND | 80180506 |
| 2090-BL23E33-02D-03RO-ND | BL23E33-02D-03RO |
| 403-3011222006-ND | 3011222006 |
| 403-3011224002-ND | 3011224002 |
| 403-3011352003-ND | 3011352003 |
| 403-3011224010-ND | 3011224010 |
| 403-3011224011-ND | 3011224011 |
| 403-3011224003-ND | 3011224003 |
| 403-3011352002-ND | 3011352002 |
| 403-7011905898-ND | 7011905898 |
| 966-1661-ND | 80280013 |
| 966-1652-ND | 80149523 |
| 966-1653-ND | 80149525 |
| 966-1654-ND | 80149527 |
| 966-1659-ND | 80280001 |
| 966-1671-ND | 80289713 |
| 966-1907-ND | 80140510 |
| 1188-MG-6-48-ND | MG-6-48 |
| 1188-MG-6-120-ND | MG-6-120 |
| 1670-VZ4FC1B0951788UTR-ND,1670-VZ4FC1B0951788UCT-ND,1670-VZ4FC1B0951788UDKR-ND | VZ4FC1B0951788U |
| 1670-VZ6DC1B1750093-ND | VZ6DC1B1750093 |
| 1188-MOTOR-KV1000-ND | MOTOR-KV1000 |
| 1738-FIT1001-ND | FIT1001 |
| 2090-SLU16CH036-24-M16-1024-ND | SLU16CH036-24-M16-1024 |
| 1670-VW0625SS001D-ND | VW0625SS001D |
| 1471-MIKROE-4302-ND | MIKROE-4302 |
| 2090-BL17E19-02-RO-ND | BL17E19-02-RO |
| 2090-BL23E22-02-RO-ND | BL23E22-02-RO |
| 2090-BL23E22-01-RO-ND | BL23E22-01-RO |
| 2090-BL17E28-02-RO-ND | BL17E28-02-RO |
| 2090-BL17E40-01-RO-ND | BL17E40-01-RO |
| 2090-BL17E40-02-RO-ND | BL17E40-02-RO |
| 942-BLDC40P30A-ND | BLDC40P30A |
| 2090-BL23E33-01-RO-ND | BL23E33-01-RO |
| 942-BLDC24P24A-ND | BLDC24P24A |
| 942-BLDC24P16A-ND | BLDC24P16A |
| 942-BLDC36P16A-ND | BLDC36P16A |
| 942-BLDC36P35-ND | BLDC36P35 |
| 942-BLDC40P20A-ND | BLDC40P20A |
| 2090-BL34E21-02-RO-ND | BL34E21-02-RO |
| 2090-BL23E48-02-RO-ND | BL23E48-02-RO |
| 2090-BL23E33-02-RO-ND | BL23E33-02-RO |
| 2090-BL34E21-01-RO-ND | BL34E21-01-RO |
| 2090-BL34E34-01-RO-ND | BL34E34-01-RO |
| 2090-BL34E27-02-RO-ND | BL34E27-02-RO |
| 942-BLDC40P10A-ND | BLDC40P10A |
| 942-BLDC40S40A-ND | BLDC40S40A |
| 966-1640-ND | 80140051 |
| 80149511-ND | 80149511 |
| 966-1639-ND | 80140043 |
| 966-1651-ND | 80149520 |
| 80149623-ND | 80149623 |
| 80149624-ND | 80149624 |
| 80149519-ND | 80149519 |
| 80149632-ND | 80149632 |
| 80149516-ND | 80149516 |
| 80149524-ND | 80149524 |
| 80149633-ND | 80149633 |
| 80149521-ND | 80149521 |
| 80149522-ND | 80149522 |
| 80141018-ND | 80141018 |
| 80141020-ND | 80141020 |
| 80149625-ND | 80149625 |
| 80149626-ND | 80149626 |
| 80141021-ND | 80141021 |
| 80149627-ND | 80149627 |
| 80149526-ND | 80149526 |
| 80141026-ND | 80141026 |
| 80149635-ND | 80149635 |
| 966-1649-ND | 80141025 |
| 80141023-ND | 80141023 |
| 80141024-ND | 80141024 |
| 80149634-ND | 80149634 |
| 80149636-ND | 80149636 |
| 80149628-ND | 80149628 |
| 80149629-ND | 80149629 |
| 80149630-ND | 80149630 |
| 80149631-ND | 80149631 |
| 80149637-ND | 80149637 |
| 80149513-ND | 80149513 |
| 80149638-ND | 80149638 |
| 80149639-ND | 80149639 |
| 80149640-ND | 80149640 |
| 966-1642-ND | 80140301 |
| 80180051-ND | 80180051 |
| 80149529-ND | 80149529 |
| 966-1657-ND | 80149642 |
| 80149641-ND | 80149641 |
| 80141012-ND | 80141012 |
| 80141014-ND | 80141014 |
| 80281007-ND | 80281007 |
| 80281009-ND | 80281009 |
| 80149531-ND | 80149531 |
| 966-1656-ND | 80149530 |
| 80149532-ND | 80149532 |
| 966-1670-ND | 80289710 |
| 80149644-ND | 80149644 |
| 80149645-ND | 80149645 |
| 80149512-ND | 80149512 |
| 80149643-ND | 80149643 |
| 966-1666-ND | 80281012 |
| 80281015-ND | 80281015 |
| 966-1658-ND | 80180301 |
| 80281011-ND | 80281011 |
| 80281013-ND | 80281013 |
| 966-1672-ND | 80289716 |
| 80149646-ND | 80149646 |
| 80149648-ND | 80149648 |
| 80289711-ND | 80289711 |
| 80289712-ND | 80289712 |
| 80149647-ND | 80149647 |
| 80149649-ND | 80149649 |
| 966-1673-ND | 80289717 |
| 80289718-ND | 80289718 |
| 80289714-ND | 80289714 |
| 80289715-ND | 80289715 |
| 80149514-ND | 80149514 |
| 80289719-ND | 80289719 |
| 80289721-ND | 80289721 |
| 966-1674-ND | 80289720 |
| 80149510-ND | 80149510 |
| 80281016-ND | 80281016 |
| 80281018-ND | 80281018 |
| 966-1675-ND | 80289722 |
| 966-1668-ND | 80281017 |
| 80281020-ND | 80281020 |
| 966-1676-ND | 80289723 |
| 80289724-ND | 80289724 |
| 966-1677-ND | 80289725 |
| 80289726-ND | 80289726 |
| 80289727-ND | 80289727 |
| 2171-EMCA-EC-67-S-1TM-DIO-ND | EMCA-EC-67-S-1TM-DIO |
| 2171-EMCA-EC-67-S-1TE-DIO-ND | EMCA-EC-67-S-1TE-DIO |
| 2171-EMCA-EC-67-S-1TE-CO-ND | EMCA-EC-67-S-1TE-CO |
| 2171-EMCA-EC-67-S-1TE-EC-ND | EMCA-EC-67-S-1TE-EC |
| 2171-EMCA-EC-67-S-1TE-EP-ND | EMCA-EC-67-S-1TE-EP |
| 2171-EMCA-EC-67-S-1TE-PN-ND | EMCA-EC-67-S-1TE-PN |
| 2171-EMCA-EC-67-M-1TE-DIO-ND | EMCA-EC-67-M-1TE-DIO |
| 2171-EMCA-EC-67-M-1TE-CO-ND | EMCA-EC-67-M-1TE-CO |
| 2171-EMCA-EC-67-M-1TE-PN-ND | EMCA-EC-67-M-1TE-PN |
| 2171-EMCA-EC-67-M-1TE-EP-ND | EMCA-EC-67-M-1TE-EP |
| 2171-EMCA-EC-67-M-1TE-EC-ND | EMCA-EC-67-M-1TE-EC |
| 2171-EMCA-EC-67-S-1TM-CO-ND | EMCA-EC-67-S-1TM-CO |
| 2171-EMCA-EC-67-S-1TM-EC-ND | EMCA-EC-67-S-1TM-EC |
| 2171-EMCA-EC-67-S-1TM-EP-ND | EMCA-EC-67-S-1TM-EP |
| 2171-EMCA-EC-67-S-1TM-PN-ND | EMCA-EC-67-S-1TM-PN |
| 2171-EMCA-EC-67-M-1TM-DIO-ND | EMCA-EC-67-M-1TM-DIO |
| 2171-EMCA-EC-67-M-1TM-CO-ND | EMCA-EC-67-M-1TM-CO |
| 2171-EMCA-EC-67-M-1TM-EC-ND | EMCA-EC-67-M-1TM-EC |
| 2171-EMCA-EC-67-M-1TM-EP-ND | EMCA-EC-67-M-1TM-EP |
| 2171-EMCA-EC-67-M-1TM-PN-ND | EMCA-EC-67-M-1TM-PN |
| 3982-DCM-1031-ND | DCM-1031 |
| 80081001-ND | 80081001 |
| 80081002-ND | 80081002 |
| 80081003-ND | 80081003 |
| 80081004-ND | 80081004 |
| 80081006-ND | 80081006 |
| 80089704-ND | 80089704 |
| 80089705-ND | 80089705 |
| 80089706-ND | 80089706 |
| 80141001-ND | 80141001 |
| 80141002-ND | 80141002 |
| 80141003-ND | 80141003 |
| 80141004-ND | 80141004 |
| 80149604-ND | 80149604 |
| 966-1815-ND | 80149605 |
| 80149606-ND | 80149606 |
| 80180001-ND | 80180001 |
| 80180002-ND | 80180002 |
| 80181001-ND | 80181001 |
| 80181002-ND | 80181002 |
| 80181003-ND | 80181003 |
| 80181004-ND | 80181004 |
| 80181010-ND | 80181010 |
| 80181011-ND | 80181011 |
| 80181012-ND | 80181012 |
| 80181013-ND | 80181013 |
| 80181015-ND | 80181015 |
| 80189701-ND | 80189701 |
| 80189702-ND | 80189702 |
| 80189703-ND | 80189703 |
| 80189704-ND | 80189704 |
| 80189705-ND | 80189705 |
| 80189706-ND | 80189706 |
| 750-90002-ND | 750-90002 |
| 80030002-ND | 80030002 |
| 80030003-ND | 80030003 |
| 80032504-ND | 80032504 |
| 80035511-ND | 80035511 |
| 80042001-ND | 80042001 |
| 80049603-ND | 80049603 |
| 1597-1207-ND | 108990008 |
| 1597-1208-ND | 108990009 |
| 1597-1209-ND | 108990010 |
| 80141006-ND | 80141006 |
| 80149501-ND | 80149501 |
| 80149505-ND | 80149505 |
| 80149506-ND | 80149506 |
| 80149507-ND | 80149507 |
| 80149601-ND | 80149601 |
| 80149602-ND | 80149602 |
| 80149603-ND | 80149603 |
| 80149616-ND | 80149616 |
| 80149617-ND | 80149617 |
| 80289701-ND | 80289701 |
| 80289702-ND | 80289702 |
| 80289703-ND | 80289703 |
| 1670-VW0625AB001F-ND | VW0625AB001F |
| 1670-VW0825AB001F-ND | VW0825AB001F |
| 80190502-ND | 80190502 |
| 1670-VW0934AB001F-ND | VW0934AB001F |
| 1670-VBL1840B-001-ND | VBL1840B-001 |
| 966-1912-ND | 80350001 |
| 966-1913-ND | 80360001 |
| 966-1914-ND | 80370001 |
| 108990061-ND | 108990061 |
| 108990060-ND | 108990060 |
| 3982-DCM-1036-ND | DCM-1036 |
| 2685-MOT-I-81542-B-ND | MOT-I-81542-B |
| 4170-BL23E22-02-HP05-ED1000-ND | BL23E22-02-HP05-ED1000 |
| 4170-BL23E22-02-HP10-ED1000-ND | BL23E22-02-HP10-ED1000 |
| 4170-BL23E48-02-HP05-ED1000-ND | BL23E48-02-HP05-ED1000 |
| 4170-BL23E22-02-HP50-ED1000-ND | BL23E22-02-HP50-ED1000 |
| 4170-BL23E22-02-HP20-ED1000-ND | BL23E22-02-HP20-ED1000 |
| 4170-BL23E33-02-HP50-ED1000-ND | BL23E33-02-HP50-ED1000 |
| 4170-BL23E33-02-HP20-ED1000-ND | BL23E33-02-HP20-ED1000 |
| 4170-BL23E48-02-HP50-ED1000-ND | BL23E48-02-HP50-ED1000 |
| 4170-BL23E48-02-HP20-ED1000-ND | BL23E48-02-HP20-ED1000 |
