Hello.
I am looking for the male and female connectors that plug into the Bose amplifier on my 2024 Mazda CX-5.
There are 3 connectors that I would like to identify. (1) black 8-pin, (1) green 16-pin, (1) black 16-pin
I greatly appreciate your help!
Welcome to the DigiKey tech forum. I did some searching for these and they appear to be a TE Connectivity automotive connector but not one I could find listed in our system. Other than the PBT GF markings are there any other numbers on these housings you can provide for reference ?
They kind of look like the multi-lock series from TE, some 8 and 16 position housings found here
If you’re able to measure the pitch (distance between the center of the pins) on these it would help verify. These housings have few different pitch sizes as seen on the Pitch filter.
Seems like the black ones could be A104964-ND and A122358-ND but we don’t seem to have green ones in multi lock series.
Hello.
Thank you both for your quick assistance!
Unfortunately there are no markings on the connectors other than “PBT-GF16” on the green 16-pin.
I will measure the pitch in the connectors and compare them to the connectors that were suggested.
