28Vdc adapter straight plug compatible with DC Jack
Aoa, I need help that this is adapter digikey part number (2622-EDP125-280-MB1-110-ND) and DC Jack digikey part number (839-1291-ND). Are they both compatible? Is this DC jack hole is 2.1mm compaitble or 2.5mm compatible?
Kindly advise asap. Ill be very thankful to you.
Regards,
Muhammad Abdullah
Hello @m.abdullah4757 ,
Thank you for contacting DigiKey TechForum. 2.1mm is not compatible with 2.5mm. The 2.5mm connector jack that will work with this supply would be 839-1292-ND, click here.
Please let us know if you have any further questions.
