2sc4060 transistor
I need an alternative for a 2sc4060 transistor.
thanks for sharing …
Hello minkc6861,
The 2SC4060 is a high voltage NPN transistor likely used as the horizontal output driver in a tube-type television.
As you pointed out, DigiKey does not offer this device.
May I recommend you search for a substitute from the NTE Electronics Inc. line of semiconductors. DigiKey does carry many, but not all, of the NTE substitutions.
To help you with the substitution, please follow this video I constructed before joining the DigiKey team.
Best Wishes,
@minkc6861
Also the below link shows the alternatives I had found for the 2SC4060.
NPN Single Bipolar Transistors | Bipolar (BJT) | Transistors | Electronic Components Distributor DigiKey
