I am looking at purchasing a detector that is 9mm by 9mm in size with x3 1.27mm pitch SMT pins. Am not really sure exactly what I am looking for, currently was thinking of finding a housing then soldering a wire to the housing to then be able to use a more common/cheaper/easier obtained connector to use for the survey meter.
Welcome to the DigiKey TechForum kca12.
What kind of detector are you looking for? The part number you mentioned is a 6 position female connector that mount to a circuit board, with 6 pins (3 on each side).
Or are you just looking for a connector to plug your detector into?
Just the connector to plug it in to. I’ve been filtering out the catalog but haven’t been having much luck. The detector only has 3 pin, the part I included the link to has the pitch and pin spacing I’m looking for I think.
Would you happen to know if such size connectors exist? I am aware this is non standard size.
After getting back in touch with the detector supplier, they confirmed that the SMT pins are square M50 pins (0.4mm x 0.4mm with 1.27mm pitch), so I will need a different connector.
So now I think I am looking for what I think is like a thermocouple terminal with slots for M50 connectors not for actually T measurement but so that a lengthy wire goes out the other end.
I am not finding anything like this on our website. I am sorry. I would wait though and see if someone else posts anything. I might be jsut missing it.
