47-10070 crimper for 112116 BNC
------Question for 112116 Please Put your question below------
Will the 47-10070 crimper be able to crimp the center pin and outer jacket connector? Will it fit the job for building this connector?
Thank you for your inquiry.
The crimp die doesn’t have a 0.042inch crimp box, it wouldn’t be suitable for that connector.
Hello dtancrell,
Yes, the 47-10070 (ACX1393-ND) crimper is the correct crimper for the BNC Plug 112116 (ACX1000-ND). It will be able to crimp the center pin, and the outer cable ferrule.
Do you have a suggestion of what to use?
dtancrell,
The 47-10070 is the correct crimper for that connector.
I checked on the manufacture’s website, and it lists the crimp tool as 47-10070.
David is correct. I mistakenly looked at the interior diameter of the crimp pin.
Ok. To order that one to be able to crimp it?
