I need to know what crimper is recommended for the above pins. This forum stuff is crap. I have simple question and this is giving me suggestions that are off the mark.
Hello @perrytbiii
Welcome to the Community!
Please see the Compatible Tooling Options
91577-1 TE Connectivity Application Tooling | Crimpers, Applicators, Presses | DigiKey
2305570-1TERMINAL CUTTER, SIDE FEED DigiKey
755430-1 TE Connectivity Application Tooling | Insertion, Extraction | DigiKey
thanks! now to find one…
Does this work for the 173631-1 pin as well?
Thom
Hi @perrytbiii
As per the supplier website
91577-1 Crimp Tool — Will not work / not recommended. It is designed for.040 series 20–22 AWG contacts, not the .070 series 173631-1.
Recommended crimp tool instead: 91573-1 (CCII 070 Series Rec Tab 20–16 AWG).
