Looking for recommendations for a hand crimpers or a single crimper w/ multiple die sets to support TE’s CPC series 4 connectors.
Application is connector 207485-1, with multimate type lll+ contacts 66565-4 and type Xll contacts 66740-6. TE calls out two different crimpers. Is there a common hand crimper that can serve both contacts, or recommended third-party crimper(s)?
Hello garyr1 and welcome to the DigiKey TechForum.
I did find 2063487-1, that does have its series listed as Multimate III+ and XIII that may work for you depending on the gauge wire you are using.
Thank you. I had not seen this particular crimper searching through TE’s website. I will investigate further and confirm.
