Continuing the discussion from Connector Type:
Thank you very much. What type of crimping tool would you recommend. I can’t seem to find them on the website. Something that is economical I would prefer. Bill
Thank you for your inquiry. Which connector are you referring to on the original post? I see there are multiple solutions stated in your post from other technicians. This will help identify the crimping tool.
Thank you.
Here are the pins and sockets I want to order
| WM1101-ND | CONN SOCKET 14-20AWG CRIMP TIN | 20 | |
| WM1100CT-ND | CONN PIN 14-20AWG TIN CRIMP | 20 |
I have found the following for the part numbers:
WM1101-ND - WM17553-ND: TOOL HAND CRIMPER 14-24AWG SIDE
WM1100CT-ND - WM9999-ND: TOOL HAND CRIMPER 14-24AWG SIDE
These are the crimping tools recommended for each contact from the information on each part number. These should work for the application. If you would like to order a single crimper for both contacts, part number WM9999-ND will work for both of the contacts.
Thank you.
