we bought the part 490-17963-1-ND from DigiKey;
we try to correct match the date code information based on the COC document and the marking on product
but we can not understand what is the meaning of the marking on product itself which had different marking on different PO references and we coul dnot understand if the marking on product refer date code information too
what is the exact marking decoding information based on data sheet for this product
Hello @hulya.sahin
Welcome to the community!
As this is a public forum, i am removing any order-specific details from your post.
As per the manufacturer specification for part CSTNR4M00GH5C000R0, the expected marking is Frequency with the date code.
The manufacturing date is indicated by an EIAJ Monthly Code, where the code is based on the month and year of manufacture.
Let the date code 2443 (Year 2024, Week 43), the manufacturing month corresponds to October 2024, and the associated EIAJ code is “x”.
Therefore, the expected marking would be: 400 x
Please note that the date code marking will vary depending on the manufacturing month and year.
thank you
in that case the product we have recieved as below:
means teh DigiKey label is refering x ; but the product once customer take and open and see the marking v
because of DigiKey label& coc and the marking on product is different not customer can not supply trecibility and can not use the product because it is space company
how we can go through on that if DigiKey can give ua varante letter by quality department or if DigiKey can create a new COC document from manufacturer refering v code
Hi @hulya.sahin,
Could you please send all available details to this email (India.support@digikey.com), including the supplier labels and DigiKey label and clear images of the received part markings?
Once we receive the information, we will review the case further and confirm our findings.
yes ı will share all information thanks a lot
