6099-PE3815LF-60-ND
------Question for PE3815LF-60 Please Put your question below------
I’d like to know for the Digikey code 6099-PE3815LF-60-ND (corresponding to Pasternack PE3815LF-60) if the PIN of the connector is either MALE or FEMALE type, since I should use this assembled cable with an instrument having SHV female connector with internal pin of MALE type. Thanks and best regards.
Hello g_bastia,
The 6099-PE3815LF-60-ND cable will have a SHV plug, with a male center pin, on both ends of the cable. The manufacture lists it as a SHV male to SHV male cable assembly.
