This is an example of the sensors, I would like to know what their current replacements are.
86 / 5.000 Resultados de traducción Resultado de traducción Which sensors are similar to the optical
Hi,
Welcome to the Digikey tech forum. Do you have a part number for this sensor for reference. If not a datasheet or full part description ? What application is this sensor used in ?
Hi,
Thank you for the welcoming. This is the sensor TSL201 is an optical array sensor y el uso para lo que quiero es medir el ancho del filamento. Pero este tipo de sensores están obsoletos.
TSL2014.PDF (602.9 KB)
Thank you for the additional information. It looks like everything we carry that functions the same as that are all obsolete as well.
Specialized Sensors | Electronic Components Distributor DigiKey
