Hi Robert,
Thank you for your tutorial.
I have some problems when I want to do login (arm login: _ ). I can’t write the user and password.
Has anyone else had this issue?
Regards.
Hi Robert,
Regards.
Hi @dcm37 , with your A10-OLinuXino-LIME, how are you seeing the Login prompt? Thru the Serial terminal or HDMI port?
Regards,
Hi Robert,
HDMI port.
Regards
Hi @dcm37 , i’m currently debugging this, for reference, what was the file name of the “Root File System” you wrote to the microSD card…
Edit: Weird… usb is not detecting…
debian@arm:~$ uname -r
4.14.226-armv7-x49
debian@arm:~$ lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
So in u-boot usb works:
U-Boot SPL 2019.07-00001-g73b01f8d (May 06 2021 - 14:26:24 -0500)
DRAM: 512 MiB
CPU: 912000000Hz, AXI/AHB/APB: 3/2/2
Trying to boot from MMC1
U-Boot 2019.07-00001-g73b01f8d (May 06 2021 - 14:26:24 -0500) Allwinner Technology
CPU: Allwinner A10 (SUN4I)
Model: Olimex A10-OLinuXino-LIME
I2C: ready
DRAM: 512 MiB
MMC: mmc@1c0f000: 0
Loading Environment from FAT... Unable to use mmc 0:1... HDMI connected: Setting up a 1920x1200 hdmi console (overscan 0x0)
In: serial
Out: vga
Err: vga
Net: eth0: ethernet@1c0b000
starting USB...
Bus usb@1c14000: USB EHCI 1.00
Bus usb@1c14400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
scanning bus usb@1c14000 for devices... 1 USB Device(s) found
scanning bus usb@1c14400 for devices... 2 USB Device(s) found
scanning bus usb@1c1c000 for devices... 2 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Hit any key to stop autoboot: 0
=> boot
This might be something: EHCI failed to shut down host controller.
Retrieving file: /boot/dtbs/4.14.226-armv7-x49/sun4i-a10-olinuxino-lime.dtb
36424 bytes read in 12 ms (2.9 MiB/s)
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Loading Device Tree to 49ff4000, end 49fffe47 ... OK
Regards,
Hi Robert,
My device is /dev/sdb, the partition is /dev/sdb1 and the label is rootfs.
I have the same problem ( EHCI failed to shut down host controller.) with other systems and this board but it worked without problems.
After the message “Starting Kernel…”
It show me these messages:
CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
sun4i-usb-phy 1c13400.phy: Couldn’t request ID GPIO
Regards
