Adaptor for Keystone Electronics 11011-R
Hi, I have a Keystone Electronics 11011-R on my PCB. I want to plug a banana plug into it. What Adaptor should i use?
Hello farhad,
It appears that you would be looking for something similar to the parts linked HERE. Specifically, if you are wanting to go to regular banana, something like 501-1429-ND.
oh perfect, thank you. So this connector is called a mini banana or a banana tip?
Hi farhad,
The 501-1429-ND is considered a banana jack to pin tip plug. The female end being the banana jack (standard size) and the pin tip plug the male end. The pin tip plug is not considered a mini banana plug no. The mini banana plug to standard banan jack adapter is something like: 501-1852-ND.
I see, thank you
Hi, so we ordered the plug but it has a 0.5" tip but the 11011-R accepts only 5.1 tips, the rest of the tip is now exposed! i am having a hard time finding the right plug that has 5.1mm tip, do you know of any such plugs for the 11011-R?
