Hi all,
I have palmsens Sensor cable with banana connectors for use with MUX8-R2.
It uses 2 mm banana connectors and i want to put them into a breadboard. I believe 2 mm diameter is to big to fit into a breadboard. does anyone know of a plug adapter of some sort which would let me plug these in without any sort of soldering or messing with alligator clips?
preferrably it would have a 22-24 AWG guage sturdy pin that goes into the breadboard and a female plug which the banana plugs may insert into…on this sensor cable, these 2 mm banana plugs do not have any sort of built in spring. the female ends must have the spring. the 2 mm plug is just sort of a solid gold plated pin.
I found this on amazon and i might just buy it…
but i don’t think the banana plug female end is going to work with these 2 mm plugs
