I have a question about the ADS124S08EVM evaluation board from Texas Instruments. I am new to electronics and ADC evaluation boards, so any help would be greatly appreciated.
For our measurement setup, we would like to continuously record data from 3 or 4 NTC thermistors and one photodiode (for laser power monitoring). It is important that all measurements are synchronized. I understand that the ADC supports multiple input channels and that custom software may be possible.
My questions are:
Is it possible to automatically obtain and record data from all these sensors with a common time reference using this evaluation board? Sequential measurements are also acceptable, the data can be interpolated afterwards.
Is there any existing software, example code, or documentation that could help us implement this?
Any advice or suggestions for a more suitable evaluation board would also be very welcome.
As I understand your project, you will be measuring a system that requires multiple temperature measurement points.
You mentioned that simultaneous measurement is important. Fair enough, but what is the thermal time constant of your system. I suspect the time constant is rather slow (approximately 1 second) in which case sequential reads from a microcontroller are unlikely to add timing distortion. If on the other hand, you have a high-speed system write back, and we can explore FPGA-based options.
With regards to your questions:
Time stamp depends on your application. For slow systems, the time stamp from your PC may be good enough. For example, you can use a simple Python script to time stamp data as it is recorded to a file or database.
Point your LLM to search datasheets and application notes. Personally, I find it useful to use the LLM to organize my thoughts and to refine the project requirements. As an example, consider this strip chart recorder I “made” using AI.
As for development boards, you may want to consider the MIKROE click boards such as the ADC 10 CLICK which features the closely related TI ADS122U04. Note that you will need to purchase a development board for the MIKROE board. There are many available. Here is a recent example where I used an Arduino board.
Best wishes,
P.S. you would need several click board to accommodate all of your thermal sensors and photodiode.
To provide some additional context, for my MSc thesis we are developing a laser calorimetry setup to measure the optical absorption of a silicon sample. Part of the laser light is absorbed, causing the sample to heat up. We expect a temperature rise of ~6 mK after 5 minutes of illumination. The thermal time constant of our sample is estimated to be ~7.6 minutes.
Indeed, precise simultaneous measurements of the NTCs are not necessary. We plan to attach two NTCs to the sample and use another to monitor the temperature inside the thermally isolated chamber (in which our sample is placed in). The photodiode is used to monitor the laser power.
The timestamps are mainly needed to fit the temperature curves and determine when the laser switches on and off, which is important for our data analysis. I indeed think that PC timestamps should be sufficient for this.
My main question is whether the ADS124S08EVM can automatically and continuously record these four channels using custom software. Would this be possible using the board’s existing USB interface, or would additional hardware be required?
My apologies if these are basic questions. My background is mainly in optics, and much of what I have learned about the electronics so far has been with the help of an LLM
No shade implied with the LLM. It’s a good way to learn electronics provided I don’t outsource my thinking to it!
The demo boards in this class are designed to showcase the hardware, in this case, the TI ADS124S08, or ADS114S08. The board includes a TM4C1294NCPDT microcontroller as an interface between the ADS analog front end and the USB leading to the “Data Analysis client” demo software.
It looks like you are trying to replace the Data Analysis client with your own software.
There are a few general approaches:
Collect data from within the Data Analysis client and then manually export it.
Determine if the existing USB interface supports a simple interface that could be read by a program such as PuTTY or Python to then record data to a file. We may or may not be able to use the Data Analysis client to configure the TM4. Which is to say, the TM4 may or may not remember the settings between sessions.
Determine if the Data Analysis client can push data to a file.
Reprogram the TM4 microcontroller to perform the desired function and interface with your recording software.
My apologies as I can offer little assistance beyond these general recommendations. You may find folks with more knowledge on TI E2E support forums.
One might note that the intended use of an evaluation board is for evaluation of some target device and its behaviors; not so much as a general-purpose measurement tool.
If the goal is to gather data rather than to observe the behaviors of a particular IC, use of a purpose-built data acquisition (DAQ) device may be worth considering, as hardware/software products specifically adapted to such purposes.
Some particular integrated circuit and its evaluation board may offer more specialized functionality, at a cost of introducing additional variables needful of appropriate configuration. That’s a disadvantage because A) one needs to understand those variables before being able to properly use the tool, and B) so does anybody else who wants to thoroughly understand and interpret any research product derived from their use.
Regarding “time stamps,” there’s a large difference between absolute chronology and simply obtaining a multi-channel data set indexed to a common point in time.
If the laser power measurement does not itself constitute a reference for when it’s “off” or “on”, then using a separate data input channel to measure whatever other quantity that one wishes to use for that determination is a possibility.
“Synchronized” in an electronics context commonly implies a precision sufficient for measuring how long it takes a radio wave to travel a few inches, and mentioning “laser” at the same time points suspicions in that direction. It sounds like you’re doing something closer to garden-variety thermometry on time scales of minutes however, in which case a run of the mill, multiplexed DAQ unit with a few milliseconds (at most) of skew between channels isn’t likely to introduce problems.
Understanding the various transducers, their outputs, and what one needs to do in order to match them to the inputs of the chosen measurement device is a good first step.
I had not realized that the evaluation board would function as a separate DAQ system. I initially thought it could simply be connected to an existing DAQ system for data acquisition.
It indeed makes more sense to investigate dedicated DAQ systems now. Fortunately, the lab where I am working already has an existing DAQ system. I will check whether it meets our requirements and, if necessary, look into purchasing a separate system.
