Hi all,
I’m looking for a alternate or substitution for a JCS5N50CF MOSFET. This is needed for a repair on a Ryobi battery charger model P118. I am fairly new to this and am not 100% sure how far I can vary from the original specs on the stock part. Any help would be greatly appreciated. Thank you all for your time.
@salisbury52
The below link shows the options I found based on the datasheet I found for the JCS5N50 devices.
TO-220-3 Single FETs, MOSFETs | FETs, MOSFETs | Transistors | Electronic Components Distributor DigiKey
Please review the datasheets to ensure the alternative will work for your application.
Thank you very much. I will look at your suggestion’s and choose from there.
Do you think I will have any issue with either of you recommendations because of the ohm difference?
