MOSFET 2SK214 & 2SJ77 Substitute
I am in urgent need for currently-available substitutes for 2SK214 & 2SJ77 (matched pair) lateral MOSFET’s in T0-220 package, as these seem no longer to be available. (I could use the higher voltage 2SK216/2SJ77 pair but these also seem to be unobtainium.) Any suggestions would be highly appreciated!
Hello Resoundaudio and welcome to the DigiKey TechForum.
Unfortunately, I am not seeing that we have any lateral MOSFETs in the TO-220 package. The closest I could find electrical spec wise would be those linked HERE, based on the information I could find for the 2SK216. This link is only the N-Channel, if any of those would happen to work for you, you can let us know and we can see if we can find a matched pair for it.
Thank you for the quick response. I will indeed look at the data on these devices.
I was able to find 2SK215, 2SK216, 2SJ78 and from reputable sellers on line. These parts are essentially the same but rated for higher voltage. So the immediate problem is solved I hope.
Should read “I was able to find new 2SK216 and 2SJ79”. Apologies for the confusion.
