Alternate to DigiKey part # 1948-2241-ND
Looking for a fit , form and function alternate to DigiKey part # 1948-2241-ND
Hello, Rich. Welcome to TechForum!
The closest options I can see for a perfect replacement are all illuminated, unfortunately. Those can be found here: https://www.digikey.com/short/zp2zz7
You can opt to leave the illumination disconnected, however, and they should otherwise function pretty much the same as your given switch. Might this be a start point?
As a subset of Matt’s selection, these have the same gold-plated contacts rated for small signals:
https://www.digikey.com/short/zpn78q
