Help! I need an equivalent sub for this power switch
Needed the attached switch. No longer being manufactured evidently.
Hello dennisfrancis,
Thank you for contacting the DigiKey TechForum.
The closest options I found, is ZNE18FA200BKOG2UEEL-ND, which will mount differently, and will have 6 solder lugs instead of just 2 lugs. You can connect 2 wires to it, and it will function as an On/Off switch.
Please check the Datasheet, to verify compatibility to your application.
