Alternative for 040/30P/KP2/L
We do not currently carry 040/30P/KP2/L but we do have 3147-300210000080-ND as an alternative. Note that this is not a drop-in replacement but the specs are similar. Please double check the datasheet to ensure it works for your application.
MFR PART # 3147-3-00-21-00-00-08-0
DIGIKEY PART # 3147-300210000080-ND
MANUFACTURER Mill-Max Manufacturing Corp.
DESCRIPTION PC Pin Terminal Connector Through Hole Gold 0.020" (0.51mm) Dia
DATASHEET Click Here
040/30P/KP2/L Datasheet:
kp_cons.pdf (3.2 MB)
