Alternative for Nidec CUS-12TB
Hi, Is there a direct alternative for the Nidec Cus-12TB. I have had this part on back order for several weeks, so was wondering if there an alternative with the same size and connection pins that I can use on the pre-printed circuit board
Hello keviom and welcome to the DigiKey TechForum.
We do have 141-EGJ1210AAG2-ND, that may work for you. The actuator dimensions and travel are slightly different. The others we have that are close can also be found linked HERE, 141-EGJ1210AAG2-ND was the only one with a 300mA rating.
