Probably an easy one for this forum. Need to find one similar to this but the side slots are in a different location.
Thanks in advance for the help.
mowclyde, regarding this particular connector, are there any markings on the housing? From the angle, it appears you may have quick connects in a housing. While I wasn’t able to find the exact part that you appear to have pictured, the following housings are what we have that would appear to be the closest options at this time: https://www.digikey.com/short/pc4w5z
Thank you.
Thank you for the additional photo. I apologize, but according to my research, I was not able to find a potential replacement for your application. I apologize for any inconvenience this may cause.
This particular type of connector, as Brandon noted, is generally referred to as a quick-connect housing or boot. it’s not actually a traditional connector; it’s an add-on piece for quick-connect terminals.
https://www.digikey.com/short/pc4v8m << The devices here are the closest general options I could find for your particular depicted part. I’m not seeing an exact match for your particular QC boot, sorry Clyde. That’s going to be unfortunately common, these tend to be more customized/proprietary parts than other, more standardized connector types. Hopefully this is a start for you, at least.
