The Artesyn LCM1500 series has a number of options to help select the AC/DC converter that best suits your application.
Here is a part number breakdown to identify what all the suffixes mean.
LCMXXXXY-A-B-C-###
Series:
Case Size
1-Phase input where XXXX =
1500 = 2.5” x 5.2” x 10.0”, 1500W
Voltage Code:
L = 12V
N = 15V
Q = 24V
R = 28V
U = 36V
W = 48V
Input Termination:
T = Terminal Block
Acoustic Noise:
Blank = Standard
Option Codes:
Blank = No Options
1 = Conformal Coat
2 = Reverse Air
3 = Options 1 & 2
4 = 5V Standby
5 = Options 1 & 4
6 = Options 2 & 4
7 = Options 1, 2, & 4
8 = Constant Current
9 = Options 1 & 8
B = Options 2 & 8
C = Options 1, 2, & 8
D = Options 4 & 8
E = Options 1, 4, & 8
F = Options 2, 4, & 8
G = Options 1, 2, 4, & 8Note: Some option code combinations may not be configured yet and will require extra leadtime the first time they are requested.
Hardware Code:
Factory assigned for modified standards.
For more information including electrical specifications, pin assignments, and mechanical drawings please see the datasheet.
LCM1500 Series Product Training Module
Currently Carried by Digi-Key
| Digi-Key Part Number | Manufacturer Part Number |
| 454-1544-ND | LCM1500Q-T-4 |
| 454-1723-ND | LCM1500W-T-4 |
| 454-1542-ND | LCM1500W-T |
| 454-1875-ND | LCM1500U-T-4 |
| 454-1545-ND | LCM1500U-T |
| LCM1500L-T-ND | LCM1500L-T |
| LCM1500N-T-ND | LCM1500N-T |
| LCM1500Q-T-8-ND | LCM1500Q-T-8 |
| LCM1500R-T-ND | LCM1500R-T |
| LCM1500R-T-8-ND | LCM1500R-T-8 |
| LCM1500W-T-8-ND | LCM1500W-T-8 |
| LCM1500R-T-4-ND | LCM1500R-T-4 |
| 454-1573-ND | LCM1500L-T-4 |
| LCM1500N-T-4-ND | LCM1500N-T-4 |
| LCM1500Q-T-B-ND | LCM1500Q-T-B |
| LCM1500W-T-B-ND | LCM1500W-T-B |
| LCM1500Q-T-1-ND | LCM1500Q-T-1 |
| LCM1500R-T-1-ND | LCM1500R-T-1 |
| LCM1500W-T-1-ND | LCM1500W-T-1 |
| LCM1500W-T-5-ND | LCM1500W-T-5 |
| LCM1500Q-T-5-ND | LCM1500Q-T-5 |
Artesyn Part Number Combinations
| Artesyn Part Numbers | ||
| LCM1500L-T | LCM1500N-T | LCM1500Q-T |
| LCM1500L-T-1 | LCM1500N-T-1 | LCM1500Q-T-1 |
| LCM1500L-T-2 | LCM1500N-T-2 | LCM1500Q-T-2 |
| LCM1500L-T-3 | LCM1500N-T-3 | LCM1500Q-T-3 |
| LCM1500L-T-4 | LCM1500N-T-4 | LCM1500Q-T-4 |
| LCM1500L-T-5 | LCM1500N-T-5 | LCM1500Q-T-5 |
| LCM1500L-T-6 | LCM1500N-T-6 | LCM1500Q-T-6 |
| LCM1500L-T-7 | LCM1500N-T-7 | LCM1500Q-T-7 |
| LCM1500L-T-8 | LCM1500N-T-8 | LCM1500Q-T-8 |
| LCM1500L-T-9 | LCM1500N-T-9 | LCM1500Q-T-9 |
| LCM1500L-T-B | LCM1500N-T-B | LCM1500Q-T-B |
| LCM1500L-T-C | LCM1500N-T-C | LCM1500Q-T-C |
| LCM1500L-T-D | LCM1500N-T-D | LCM1500Q-T-D |
| LCM1500L-T-E | LCM1500N-T-E | LCM1500Q-T-E |
| LCM1500L-T-F | LCM1500N-T-F | LCM1500Q-T-F |
| LCM1500L-T-G | LCM1500N-T-G | LCM1500Q-T-G |
| LCM1500R-T | LCM1500U-T | LCM1500W-T |
| LCM1500R-T-1 | LCM1500U-T-1 | LCM1500W-T-1 |
| LCM1500R-T-2 | LCM1500U-T-2 | LCM1500W-T-2 |
| LCM1500R-T-3 | LCM1500U-T-3 | LCM1500W-T-3 |
| LCM1500R-T-4 | LCM1500U-T-4 | LCM1500W-T-4 |
| LCM1500R-T-5 | LCM1500U-T-5 | LCM1500W-T-5 |
| LCM1500R-T-6 | LCM1500U-T-6 | LCM1500W-T-6 |
| LCM1500R-T-7 | LCM1500U-T-7 | LCM1500W-T-7 |
| LCM1500R-T-8 | LCM1500U-T-8 | LCM1500W-T-8 |
| LCM1500R-T-9 | LCM1500U-T-9 | LCM1500W-T-9 |
| LCM1500R-T-B | LCM1500U-T-B | LCM1500W-T-B |
| LCM1500R-T-C | LCM1500U-T-C | LCM1500W-T-C |
| LCM1500R-T-D | LCM1500U-T-D | LCM1500W-T-D |
| LCM1500R-T-E | LCM1500U-T-E | LCM1500W-T-E |
| LCM1500R-T-F | LCM1500U-T-F | LCM1500W-T-F |
| LCM1500R-T-G | LCM1500U-T-G | LCM1500W-T-G |
