Asking for LED baking specification
Hi,
I would like to know the baking specification (Baking temperature and baking duration) for the following component.
SFH 4726S
XPEBWT-L1-0000-00DZ5
Hello and welcome to the Forum. This part is MSL 1 and does not have any baking requirements. Please see these other Forum posts that may be helpful.
Explaining MSL (Moisture Sensitivity Levels) - Support / Tech Tips - Engineering and Component Solution Forum - TechForum │ Digi-Key (digikey.com)
Hi,
I saw a parameter in the baking spec table of IPC/JEDEC J-STD-033B called package body. I would like to know if it counts including the thickness of the packaging and the component or just the component physical body size only.
I believe the reference is to the dimensions of the component itself.
