AVX TCJ Series Case Color questions
I would like to verify that the case color of the specific part numbers below are in black. I have seen the AVX document that indicates there is a case color change from gold to black, with “E” being appended at the end, but I have purchased these before with no E at the end and have received black, and also with no E and received gold. Most of the parts listed below have the option to purchase with the E at the end, so it is a bit confusing as to what will be delivered. (DigiKey part numbers shown)
478-6638-2-ND
478-6638-1-ND
478-9425-1-ND
478-8786-1-ND
478-8057-1-ND
Thanks!
Welcome to the DigiKey TechForum. I have sent a request and will post the information as soon as I get it.
Hello.
All current stock we have for these capacitors is the color black.
AVX has a note regarding the additional character on the datasheet. They note that “E” is for black resin, but also note that it is possible to order part number without “E” as identical product. So when the part is ordered with the “E” it will be black, but when it is ordered without the “E” it could be either.
Thanks Steve for verifying the stock of these!
Thank you Steven for clarifying.
