Hello, My name is James and I am doing a student fellowship project at UTSA with the US army. I am in need of a very high end, reliable, and precise barometric sensor. If money was not an issue, what would be the best sensor y’all could recommend. If it helps I am looking for atmospheric pressure sensors. It is going into a chamber where the exact pressure needs to be replicated to a profile we script up.
You can consider DPS310.
https://www.digikey.com/en/product-highlight/i/infineon/dps310-digital-barometric-pressure-sensors
You may get some suggestions about BMP280 too.
However, it may not be the best choice… You can see the other options from Bosch too.
