Battery replacement suggestion
Please can somebody suggest a replacement for the battery below? It’s installed in an automotive GPS tracker
It measures: L80xW50xH12
Thanks in advance
I found nothing that is the same physical size.
These two options are the closest I found
Hi hsdb , Click here for an extended list, although still are not the exact physical size you need. Please note the 3 Jauch Quartz options are currently listed as lithium polymer but are actually lithium ion and our website will be updated within 2 days. If you are able to make the size work for you, you will just have to verify to replace the battery with the same chemistry as the stock battery (li-Ion or Li-Po) and then of course try to get one with a similar connector, or jerry-rig one to work.
