BMI160 - BMI270
Hi,
We would like to use the BMI160 component in one of our projects. However, we noticed that DigiKey lists this component as Obsolete. Because of this, would it be a problem to use the BMI270 instead of the BMI160? In other words, can we replace the BMI160 with the BMI270 in the same project?
Best regards.
Hello @duduberkay42
Welcome to the TechForum
I looked between these two parts and this is what I found.
Both of these parts will have the same size and pinout so it would drop directly in place of each other.
The BMI270 has a faster response speed and a lower current draw then the BMI160. there is one other difference that I noticed it seems that some of the I2C/SPI addressing is different between these chips so you may have to do some adjustments in your code.
BMI160 Datasheet
BMI270 Datasheet
