This Product Selection Guide contains information to help select products in the Board Mount Power Supply Accessories category on DigiKey.com
Board Mount Power Supply Accessories are supplementary items used with other devices in this category.
SelectionCharacteristics
Specifications to determine which Accessory is right for your application.
Accessory Type: The type of accessory that the product is, such as an adapter board, bolt, cable, thermal pad, etc.
ProductExamples
| MFR PART # | 18392 |
| DIGIKEY PART # | 1102-1575-ND |
| MANUFACTURER | Vicor Corporation |
| DESCRIPTION | INMATE MICRO OUT SL BOB |
| MFR PART # | THL-HS1 |
| DIGIKEY PART # | 1951-1275-ND |
| MANUFACTURER | Traco Power |
| DESCRIPTION | HEAT SINK FOR THL10WI/20 PWR SUP |
| MFR PART # | D1U74T-BRB |
| DIGIKEY PART # | 811-D1U74T-BRB-ND |
| MANUFACTURER | Murata Power Solutions Inc. |
| DESCRIPTION | BREAKOUT BOARD FOR CRYPTOCURENCY |
