We are having issues with the crimp sockets/crimp pins coming loose from the connector. This is due to insufficient insertion of the pins/sockets which is very difficult due to the small wire gauge. Is there an official tool we should be using to insert correctly?
I have noticed the following insertion tool, which looks correct but not sure if it would work: SA3150 Insertion Tool.
I have one of those here - used for extraction. I notice it says “insertion” too, however this doesn’t work with a cable actually crimped into the pin.
If you notice on SA3150, it is virtually the same but cut in half down the middle, allowing the tool to fit around a cable.
Appears there’s no equivalent for the sockets/pins i’m currently using.
