Bus bar 14AWG
Hi Team,
We need bus bar 14AWG solid conductor strand, Non-Insulated, Tinned Copper 5 to 10 Feet. Can anyone suggest part?
Regards,
Srikanth Kacchu
I was not able to locate that short of a run but there are 2 options that should work well in your needs and 100’ length was the shortest. please follow the link below to view the items on our website.
Thank you
Ryan
There are a few inconsistencies currently with our website filtering. If you are searching bare wire, you can select “Jacket Color” to be “None (Non-Insulated)” such like below link:
(Non-Insulated) Single Conductor Cables (Hook-Up Wire) - Filtering by “Jacket Color”
-Or you can select “Jacket (Insulation) Material” to be “No Jacketing - Bare Wire” per below link. Currently, both yield different results.
Single Conductor Cables (Hook-Up Wire) - Filtering by “Jacket Material”
We do have some of the actual busbars like 0280300000
They are listed under terminal block accessories.
https://www.digikey.com/en/products/filter/terminal-blocks-accessories/309
The other option could be using a barrier block with a jumper if that would work better.
See also:
Triton (A Molex Company) - Custom Bus Bars
