I am trying to find a bus bar similar to this for a RGB LED installation. 24v, 600W max
or anything that would function similarly (power in, dozen or so leads out)
Would something under the power distribution section here, https://www.digikey.com/short/bj2mtjft work for the application?
I was hoping to be able to use fork terminals on the wiring. I will review that category again.
We do have some of the actual busbars like 0280300000
They are listed under terminal block accessories.
https://www.digikey.com/en/products/filter/terminal-blocks-accessories/309
The other option could be using a barrier block with a jumper if that would work better.
-Robert
