BUSSMAN ATC FUSE
item 283-2319-ND EATON ATC Fuse the product i get write PACIFIC on it, is it under Eaton? got any datasheet that says PACIFIC is under Eaton? the datasheet provided did not specify any thing about PACIFIC
Hello multi69electrical, Welcome to the DigiKey TechForum.
I could not find anything on the MFG website or in our system that calls out this PACIFIC part marking, are you able to provide pictures so we can ensure it’s the correct part?
Hi multi69electrical,
Thanks for sending this in. I cannot find anything in a search that calls out Eaton Bussman and PEC (Pacific Engineering Corp) in the same company, so this part marking doesn’t seem to be correct Did you buy this fuse (283-2319-ND) through DigiKey? If so, and an RMA or credit is needed, this would have to be through email (customer.service@digikey.com) or through a phone call 1-800-344-4539.
