Cable 4x Data 2x Power
Looking for a cable for the 2150-24204131-01-ND. I have no special requirements for the shielding, since no data bus is used and the data pins are only used for signaling.
Is there any way to get a cable from somewhere instead of having to commission one yourself? I need approx 20 meters
GlobTek can do this kind of customized cable assembly for you, you can inquire through Digikey customer service in order to get a price and we can assemble it for you. You should specify the current+voltage you need to use through the power conductors and also what goes on the other end and the wiring instructions for each pin.
thanks
