Cable with this connector
hello i am looking for a cable with this connector on each side
Welcome to the DigiKey TechForum. We’ll need to identify that 2 pin header in order to find cable mount mates. Do you have a schematic of this board that possibly lists the part number for the header? Are they any markings on the housing that we could use in trying to narrow this down ?
in the service manual there is no information of this cable
in the part list there only this indication
i have find a photography of all the cable ad it look like this
Are there any markings on the plastic housing for the board or cable connector. They would be small, hard to see and probably just a couple letters or numbers.
It appears that all of the connectors are from the same series, just with different pin count. To help identify, we need to know the measurement of the pin spacing (pitch, P) from the center of one pin to the center of the next.
To get the most accurate pitch measurement, measure the length from first to last pin of the 5-pin connector and divide by 4 and report back with your results.
Looking like you have the JST PH series.
PHR-2 JST Sales America Inc. | Connectors, Interconnects | DigiKey
If you scroll down to associated product we have pre-crimped leads for these connectors.
Example in 6 inch:
ASPHSPH24K152 JST Sales America Inc. | Cable Assemblies | DigiKey
L=8mm P= 2mm
Yep, @Kristof_2649 has identified it for you.
