So far I too am not having luck finding data on that item.
In case others would have a better luck would you be able to take a wider shot?
Also what board is this on?
I’m also not sure what that is.
You might want to contact the maker of the board if you can, to see if they are willing to share some info on that.
Some one gave me this almost related datasheet.
AN_SY8366A.pdf (599.3 KB)
For the SY8366QNC I am sorry to say that I am not seeing that we list these at this time.
Hi Adam,
Thanks for the information. Could ypu please attach the datasheet in the reply because I am unable to open this website due to geological restrictions in the UK.
This looks like it is from a series of MOSFETS based on Nexperia’s PSMN4 base part number, the datasheet is linked here: PSMN4R4-30MLC N-channel 30 V 4.65 mΩ logic level MOSFET in LFPAK33 using NextPower Technology
For context you can confirm the top marking on the manufacturer’s website here. PSMN4R4 Order Info
Sorry neuservo, the datasheet isn’t available on the official website. What I’ve attached is a screenshot from a Chinese website.
I smell AI here.
Cheers, heke
Hi Adam7,
Thanks for your efforts.
I could not find a data sheet for this one.
Hi Karl_1696
Hello @neuservo,
By chance is this from a monitor?
Note that 2038 is likely a date code (38th week of 2020).
Sincerely,
