If I want to ground the negative output of DC-HVDC converter (FS series, 10W), what should I do? Whether to connect the negative output of the converter to the negative terminal of battery or should I connect simply connect the negative output of converter to any grounded object?
Hello Pujawagatika97,
Thank you for using the Digikey Techforum.
Is it possible for you to tell us what specific part number you are working with?
Sure sir…The part number is 1470-3292-ND (FS20-12)
